Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
This thread has been viewed 49 times
  • 1.  Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted Apr 23, 2024 12:21 PM
    I have been chasing a problem with our wireless network, and I wanted to create a thread about it in case others are experiencing the same issues. Since ArubaOS 10.5.1.1 we have noticed issues where an access point will report the following with some devices:
    Onboarding failed for client xx:xx:xx:xx:xx:xx in L3 phase timeout to BSSID xx:xx:xx:xx:xx:xx on channel xx of AP hostname AP-xxxx. Reason: No DHCP traffic detected
    Wireshark packet captures never show the endpoint reaching the DHCP server. Further investigation of the Aruba Central logs for all access points shows that most of these L3 Timeouts are from Apple iPhone devices. This issue appears to be alleviated if the user forgets the wireless network and rejoins it-I suspect this is due to the MAC randomization feature found on iPhones. The issue can be mitigated if the user roams to a different access point.
    Additionally, it has been observed that Apple iPhone devices sometimes rapidly roam between frequency bands on the same access point. An example of this issue is as shown in an access point log below:
    2024-04-23 08:47:47 CDT    |    Client Onboarding Failure - Deauthentication/Disassociation    |    Onboarding failed for client 12:1a:xx:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:47:47 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207
    2024-04-23 08:45:55 CDT    |    Client Onboarding Failure - Deauthentication/Disassociation    |    Onboarding failed for client 12:1a:xx:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:55 CDT    |    802.11 De-authentication to Client    |    De-authentication sent to client 12:1a:xx:xx:xx:xx from BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:55 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207
    2024-04-23 08:45:35 CDT    |    Client Onboarding Failure - Deauthentication/Disassociation    |    Onboarding failed for client 12:1a:xx:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:35 CDT    |    802.11 De-authentication to Client    |    De-authentication sent to client 12:1a:xx:xx:xx:xx from BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:35 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207
    2024-04-23 08:45:28 CDT    |    Client Onboarding Failure - Deauthentication/Disassociation    |    Onboarding failed for client 12:1a:xx:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:28 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207
    2024-04-23 08:45:18 CDT    |    802.11 De-authentication to Client    |    De-authentication sent to client 12:1a:xx:xx:xx:xx from BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:18 CDT    |    Client Onboarding Failure - Deauthentication/Disassociation    |    Onboarding failed for client 12:1a:xx:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207. Reason: Station has roamed to another AP
    2024-04-23 08:45:18 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207
    2024-04-23 08:45:05 CDT    |    Client Association Success    |    Client 12:1a:xx:xx:xx:xx associated successfully to SSID CHS-BYOD on channel 11 of AP hostname AP-HS207
    2024-04-23 08:44:21 CDT    |    Client Roaming Success    |    Client 12:1a:xx:xx:xx:xx associated to BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207 roamed successfully to BSSID 6c:c4:xx:xx:xx:xx on channel 11 of AP hostname AP-HS207
    2024-04-23 08:44:21 CDT    |    802.11 De-authentication to Client    |    De-authentication sent to client 12:1a:xx:xx:xx:xx from BSSID 6c:c4:xx:xx:xx:xx on channel 132+ of AP hostname AP-HS207. Reason: Station has roamed to another AP
    Environment details are below.
    Aruba Central Managed: Yes
    Deployed Access Points: AP-615, AP-515, AP-635, AP-535
    Affected Firmware: 10.5.1.1 and 10.6.0.0 (Latest as of the time of this writing)
    Features enabled for affected WLAN: 802.11k
    Radio settings are left mostly at default settings
    Other devices such as Windows laptops, Chromebooks, and Android devices also use this affected WLAN without issue.
    If anyone has experienced similar issues or knows a solution to this problem, I'd be interested in hearing about them. I will open a TAC soon and update the thread with its information if this issue is being experienced by others.
  • 2.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted Apr 25, 2024 02:39 PM
    Yes - there is PMK cache issues with 10.5.x.  I have not tested 10.6.x to see if the same issues occur.
    I was plagued by roaming issues with 10.4.0.x and 10.5.x.  I downgraded to 10.4.1.0 and that resolved 99% of our issues.  I had a minor issue where people that roamed too often in a short period of time got "Association Flood Detected" - this rarely happened and only to our shipping&recieving guys.  Upgrading to 10.4.1.1 resolved that issue for us.
    See this post where I gave more details and it will explain your DHCP issue you are seeing as well:
    https://community.arubanetworks.com/discussion/aruba-central-controllerless-environment-is-not-working
  • 3.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted Jun 03, 2024 03:35 PM
    Hi
    Did you ever get to the bottom of this?  We are 3 weeks into Aruba support with exactly the same symptoms and no resolution in sight.
    Devices seem fine if they have a strong signal from a single AP but as soon as they start doing a bit of roaming they either rapidly channel hop between 2.4 and 5ghz on same AP or just roam as normal between AP's.  At some point they get stuck and either disconnected and won't reconnect, connected but with "poor signal" or just connected but no actual connection.
    In all cases roaming outside the range of the effected AP and the client will reconnect again.  Roam back to problem location and it will continue to work for a while until it gets stuck again.
    I see the same errors in central as you and a LOT of "Client Onboarding Failure - Deauthentication/Disassociation" events. in fact for our environment 50% of all events are that error!
    Our Environment:
    Aruba Central
    mostly AP-515 with a few AP-535 and AP-505's
    Current firmware 10.6.0.0 and same issue on an earlier 10.5 but not sure exact version.
    Have disabled all fast roaming features and left most radio settings as default.
  • 4.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted Jun 04, 2024 01:57 AM
    Sounds like an Apple issue since every other OS works fine.
  • 5.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted Jun 04, 2024 08:50 AM
    I opened a case with Aruba and its manager immediately lept on one instance of DFS and a lack of whitelist for the DHCP server in the captive portal. The issue is hard to capture, and when it does, it's usually with an end user's personal device, which makes it hard to troubleshoot for an extended amount of time. Because of the difficulty replicating the issue and the lack of critical investigation from the assigned case manager, I let the case automatically close. The case number was 5381575380 if it is of any use.
  • 6.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted 15 days ago
    We are seeing the exact same issue.  Started on version 5.1.1 and still continues on 10.6.0.2.  We still have a TAC case open with no resolution.
  • 7.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted 14 days ago
    Please escalate your case, if there is no satisfactory progress. You could check the TAC User Guide from this location, and/or work with your local Aruba SE (or partner to get in touch). What you see may have a different root cause from what others see, so even if it looks exact the same, and as mentioned earlier, such issues can be hard to grab as it's typical unpredictable and hard to capture data from unmanaged end-user devices. After escalation, TAC may ask for different types of data.
  • 8.  RE: Apple iPhones and ArubaOS 10 - DHCP Timeouts and Roaming issues
    Posted 7 hours ago
    I am seeing very much the same issues. I was on 10.6.0.2 and went back down to 10.4.1.4 to overcome the No DHCP Traffic issue. I am seeing alot of roaming back and forth between channels on the same AP by the same client device.
