Apple TV + bridged SSID on Campus AP wont work.
  • 1.  Apple TV + bridged SSID on Campus AP wont work.
    Posted Jan 21, 2016 01:12 PM
    Is there any way to get a wired Apple TV to show up for a wireless device when the device is connecterd to a Campus AP that bridges the connection to the same vlan as the Apple TV? When running tunneled mode to the same network (via the controller) there's no problems when activating AirGroup, but it seems it wont work when we run the SSID as bridged. Am i missing something or is this not supported?
  • 2.  RE: Apple TV + bridged SSID on Campus AP wont work.
    Posted Jan 21, 2016 02:00 PM
    Do you have drop multicast/broadcast enabled in the VAP?
  • 3.  RE: Apple TV + bridged SSID on Campus AP wont work.
    Posted Jan 21, 2016 03:02 PM
    No it is not enabled, convert broadcast to unicast is enabled thou.
  • 4.  RE: Apple TV + bridged SSID on Campus AP wont work.
    Posted Jan 22, 2016 12:30 PM
    Try adding an allowall to the AP uplink session acl in the ap-system-profile.
    (C2) (config) #ap system-profile test
    (C2) (AP system profile "test") #session-acl allowall
    (C2) (AP system profile "test") #exit
    (C2) (config) #
    Rajaguru Vincent
  • 5.  RE: Apple TV + bridged SSID on Campus AP wont work.
    Posted Jan 22, 2016 01:32 PM
    ALso make sure that the wired port is in bridge mode.
