The Meru AP Apple TV configuration is "Bridged" and WPA2-psk (I did not set it up) I tried configuring the Aruba the same way,, no luck. If I put the Aruba Apple SSID into Tunnel mode.. I can connect to the Apple SSID and can connect the Apple TV to the SSID but no connection between the iPad and Apple TV....
Any ideas??
thx,
