last person joined: 11 hours ago
Application (Admin SSO Login) logs via syslog?
  • 1.  Application (Admin SSO Login) logs via syslog?
    Posted May 02, 2014 10:24 AM
    Is there a better way to get Application (Admin UI) access logs via syslog other than using the system logs?
    The biggest issue with the system logs is that there are not distinct "field" for username. It is just dumped into the description field.
    It would be great to have "Application" available inside session logs similar to RADIUS, TACACS, and WEBAUTH where there are distinct fields mapped (Common_Username, Common_Source, etc)
