Application Works on Wired Network but not on Wireless Network
  • 1.  Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 01:21 PM
    We have an application that works on the wired network, but not on our controller based wireless network. It uses UDP port 7700. The wired and wireless networks are on two different VLANs. But, tagging through the wireless VLAN to a wired port gets the app working, indicating our egress firewall configuration is probably not the issue. Do you have any suggestions on how this might be debugged?
    Robert
  • 2.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 01:28 PM
    Does it require multicast discovery? (SSDP/DLNA/mDNS)
    Tim
  • 3.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 02:52 PM
    Looking at the wired packet capture shows unicast UDP. Looking at show datapath session seems to imply it is being denied. The device is in the right role and the IPv4 policy is any any any permit.
    10.61.251.81 109.123.157.210 17 51995 7700 0/0 0 0 0 tunnel 1230 9 0 0 FDYC
    Any ideas?
    Robert
  • 4.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 04:53 PM
    What role is the user in?  What is the output of "show rights <role>"?
  • 5.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 05:18 PM
    show rights EmployeeComputer
    Derived Role = 'EmployeeComputer'
    Up BW:No Limit   Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Assigned VLAN = 250
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Web Content Classification: Enabled
    ACL Number = 90/0
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                         Type     Location
    1         global-sacl                  session
    2         apprf-EmployeeComputer-sacl  session
    3         allowall                     session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
    allowall
    1         any     any          any                   permit                           Low                                                           4
    2         any     any          any-v6                permit                           Low                                                           6
    Expired Policies (due to time constraints) = 0
  • 6.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 05:20 PM
    You should open a TAC case in parallel.  You could have an ACL on a port or enabled filtering on the AppRF dashboard...
  • 7.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 21, 2015 05:38 PM
    Opened ticket.
  • 8.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 22, 2015 04:34 PM
    I've been working with TAC and have made some progress. But, the engineer had to get on another call. What we were able to see is the device we are trying to connect with on UDP 7700 is behind an IAP and for whatever reason, the device's Internet facing IP address has the logon role on the contoller which is denying access. How could that be?
  • 9.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 22, 2015 04:36 PM
    That usually means AAA is enabled on that interface/VLAN and/or the interface/VLAN is untrusted.
    Tim
  • 10.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 23, 2015 03:01 PM
    I worked with TAC a bit more today and have more info. I also found this page that explains the roles an IAP setup gets. http://community.arubanetworks.com/t5/Controller-less-WLANs/What-are-the-roles-that-IAP-gets-when-configured-as-IAP-VPN/ta-p/185738
    We are trying to access a service behind the outer IP used to connect an IAP. I think because the outer IP entry has the logon role on the controller, traffic is being denied. TAC is looking into this more.
    Does anyone have any suggestions based on this new info?
    Robert
  • 11.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 23, 2015 11:52 PM
    rwilsonblue,
    There are so many ways to set it up, that I'm not sure anyone can guess what your situation is.  We didn't know you were doing IAP-VPN.  Please keep us up to date on how it is progressing with TAC.
  • 12.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 24, 2015 09:47 AM
    When I started this thread, I didn't think about this device being on the same network as an IAP. As we worked with TAC on it, they were able to see the IAP configuration is causing the issue. We have it working by allowing UDP 7700 on the logon role, at least from a Windows laptop. IOS devices are not able to connect and I'm starting to debug that now.
  • 13.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 24, 2015 10:29 AM
    Running show datapath session table <clientip> on the mobile device's IP shows flags FDYC, just like we were seeing before, except the protocol was 6 instead of 17. Adding TCP/7700 to the logon role got the mobile devices working.
    I'm going to consult with some folks to see if the way we are using the IAPs is the best scenario.
    Robert
  • 14.  RE: Application Works on Wired Network but not on Wireless Network
    Posted Sep 24, 2015 12:42 PM
    Adding a bit more info, another location has a RAP and it had the same issue.
