last person joined: 7 hours ago
Applying ACL to pre-auth role from Aruba Central
  • 1.  Applying ACL to pre-auth role from Aruba Central
    Posted May 24, 2019 02:35 AM
    I am having trouble finding how to apply ALC / white list for social login from Aruba Central.
    Set up is AruabInstant manage from Aruba central and Clearpass for authentication.
    Guest via clearpass self registering portal. everything works with self regiter guests and they placed on to guest role I have defined.
    However when I add socila login on clearpass (google / facebook), I need to whitelist google/facebook logon sites.  Can't find way to whitelist or add ACL to pre-auth role.
    whilist in walled garden does not working.
    IAPs on v8.4.0.2
    any helpful leads ?
  • 2.  RE: Applying ACL to pre-auth role from Aruba Central
    MVP EXPERT
    Posted May 24, 2019 03:28 AM
    In 6.5.4.x and above you use a domain ACL instead. So for example Allow https on domain facebook.com within your User Role
  • 3.  RE: Applying ACL to pre-auth role from Aruba Central
    Posted May 24, 2019 10:19 AM
    Thanks,  Found it.
  • 4.  RE: Applying ACL to pre-auth role from Aruba Central
    MVP EXPERT
    Posted May 24, 2019 10:33 AM
    You can see the option for a pre-auth role (e.g a User Role you have already created...) at the bottom of the Access portion of the wizard when creating a Role Based WLAN.
    So Networks -> [WLAN ] -> Access.
  • 5.  RE: Applying ACL to pre-auth role from Aruba Central
    Posted May 24, 2019 10:34 AM
    I found the option to do pre auth role.  It was under "Access" at the bottom of page.
  • 6.  RE: Applying ACL to pre-auth role from Aruba Central
    Posted Sep 16, 2020 06:41 AM
    Where is the Pre-auth role in the latest Central update?
    It seems to be a missing option under "Access" within "WLANs".
    Doesn't seem to be under "Security" either....
