Applying ARM Profiles to single AP groups
  • 1.  Applying ARM Profiles to single AP groups
    Posted Jul 11, 2017 06:52 AM
    How do I apply ARM profiles to single AP group.
    It seems that when I apply the new ARM profile to the ap-group it applies to all the groups on the Master controller.
    How to I apply it to a single group in the GUI and or the CLi
  • 2.  RE: Applying ARM Profiles to single AP groups
    Posted Jul 11, 2017 07:08 AM
    The ARM profile is part of the 11a and 11g radio profile. You will need to define a unique radio profiles for your new ARM profile, which can then be applied individually to an AP group.
    #AirheadsMobile
  • 3.  RE: Applying ARM Profiles to single AP groups
    Posted Jul 11, 2017 07:12 AM
    The ARM profile is subordinate to and tied to the radio profile.  Create a new Radio Profile using Configuration> Advanced Services> All Profiles> RF Management> 802.11a (or 802.11g) radio>.  Type the name of the new radio profile and click on Add.  To back to All Profiles> RF Management> ARM Profile, type the name of a new profile you would create and type Add.  Go back to All profiles> RF Management> 802.11a or g radio and find your radio profile.  Assign your created ARM profile to that radio profile.
    Go to Configuration> Wireless > AP Configuration.  Click on the AP Group you want to assign the radio profile to.  Expand RF Management.  Click on 802.11a or 802.11g radio profile.  Change the dropdown to the right to the radio profile you created above.  That will assign the radio profile and then the ARM profile to the AP group that you want.
    I hope this helps.
  • 4.  RE: Applying ARM Profiles to single AP groups
    Posted Jul 11, 2017 07:33 AM
    Thanks Guys,
    I was applying it at the ARM level and not at the radio level.
