AppRF more than 15 minutes
  • 1.  AppRF more than 15 minutes
    Posted May 20, 2015 03:29 AM
    Hi everyone.
    Is there a way to view AppRF statistics more than 15 minutes? (day, week, etc...)
    What do we need for it?
    As I see on InstantOS - it's not possible. Is it right?
    Aruba Central does not provide AppRF statistics at all. Is is right?
    Mobility Controller?
    AirWave?
    Or do we need some external billing or proxy system (like Kerio Control) to collect deep user statistics?
  • 2.  RE: AppRF more than 15 minutes
    Posted May 20, 2015 07:34 AM
    You would need Airwave to collect historical statistics on your devices.  You can always ask your Aruba representative for a free evaluation of Airwave.  Let me check to see if Central will support historical AppRF statistics.
  • 3.  RE: AppRF more than 15 minutes
    Posted Aug 28, 2015 03:36 PM
    Colin Joseph,
    Did you already see if the Aruba central will support or already support AppRF ?
    Can you share your results ?
    Thanks.
  • 4.  RE: AppRF more than 15 minutes
    Posted Aug 28, 2015 04:07 PM
    rfRocha,
    It is currently in beta right now.  I will post back here when it is commercially available.
