  • 1.  AppRF on IAP
    Posted Apr 15, 2015 03:38 AM
    Dear Support,
    Is there any document to show AppRF supported platform?e.g. what model and which version is required for AppRF?
    I have a IAP135 and I find that it is not support AppRF...
    Alvin
  • 2.  RE: AppRF on IAP
    Posted Apr 15, 2015 05:59 AM
    Which code you are using ? it supports from 6.3.
    BTW it is not a model specific feature, it is a code specific feature.
    Please feel free for any further query on this.
  • 3.  RE: AppRF on IAP
    Posted Apr 15, 2015 06:04 AM
    Dear Support,
    Do you mean the version?
    I am using 6.4.0.3-4.1.0.1_45063
    Many Thanks
    Alvin
  • 4.  RE: AppRF on IAP
    Posted Apr 15, 2015 06:21 AM
    Yes . this code should support AppRF.
    Only 92/93 do not support this feature. rest of the models should support.
    For your ref , snapshot from the release notes.
    Please feel free for any further help on this.
  • 5.  RE: AppRF on IAP
    Posted Apr 15, 2015 06:30 AM
    Dear Support,
    Thanks for your ref.
    I have seen the words under your mark. my model is IAP135,
    It that I have only can use web filter and no application control?
    is that mean all other IAP except "IAP92/93 no AppRF and 104/105 134/135 3WN/3WNP only web filter" will support application control and web filtering?
    Many Thanks
    Alvin
  • 6.  RE: AppRF on IAP
    Posted Apr 15, 2015 07:15 AM
    Yes,
    Only those platforms do not support Application based access rules, all other support full functionality of DPI.
    For your ref ( From the User Guide ) :
