Is there any way to generate reports based on AppRF activity on the Instant platform.
If you have an Airwave server, you can run an AppRF report from that.
Hi Vishnu, I have Airwave 8.2.0.2, the guide says go to Home>AppRF but I can't see that option, does it need to be enabled or do I need higher permissions to view?
Do we see AppRF data populating under Home --> AppRF page? if not you would have to enable it on IAP and Airwave.
For running reports you can go to Reports --> Definition on Airwave and create a new report definition with type as AppRF.
Vishnu, Its a permissions issue, once this is sorted I expect to see these options on the home and reports pages. Thanks for your help.
