APPRF VISIBILITY Can't Enable
  • 1.  APPRF VISIBILITY Can't Enable
    Posted May 03, 2016 02:47 PM
    Hello Aruba Community, so the thing is that I have:
    Name:Aruba Operating System Software
    Type:225
    Build Time:2015-12-18 23:46:04 PST
    Version: 6.4.4.3-4.2.2.0_53034
    And the option AppRF can't enable, always show disable...
    any comments?
  • 2.  RE: APPRF VISIBILITY Can't Enable
    Posted May 03, 2016 03:06 PM
    known bug. kindly upgrade to 4.2.3 you will be fine. :)
  • 3.  RE: APPRF VISIBILITY Can't Enable
    Posted May 04, 2016 03:54 PM
    I have the upgrade and still wont fix
    I downloaded it from
    LifetimeWarrantySoftware
  • 4.  RE: APPRF VISIBILITY Can't Enable
    Posted May 04, 2016 03:56 PM
    upgrade to 4.2.3 please. :)
  • 5.  RE: APPRF VISIBILITY Can't Enable
    Posted May 04, 2016 04:16 PM
    Sorry can´t do that... system say that there is no new version
    Can You show me where can i download the UPDATE, please.
  • 6.  RE: APPRF VISIBILITY Can't Enable
    Posted May 04, 2016 04:35 PM
    get it manually from here and upgrade:
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/Default.aspx
    The auto detect feature for new image, does not work for early availablity releases.
  • 7.  RE: APPRF VISIBILITY Can't Enable
    Posted May 04, 2016 05:05 PM
    You ARE A GENIUS SIR!!!!!!!
    It WORKED!!!!!! THANKS for the HELP :)
  • 8.  RE: APPRF VISIBILITY Can't Enable
    Posted May 30, 2016 09:04 PM
    I don't see 4.2.3.0 in the Early Releases folder.   Has it been removed or superceded?
  • 9.  RE: APPRF VISIBILITY Can't Enable
    Posted May 31, 2016 10:56 AM
    It is still there, you may bee llooking in the wrong place.
    try:
    Root collection/Aruba instant/ early deployment / current release
  • 10.  RE: APPRF VISIBILITY Can't Enable
    Posted Aug 22, 2016 09:25 AM
    I've resolv this with the new version release:
    ArubaInstant_Centaurus_6.4.4.4-4.2.3
    Regards!
