Approaching radius ID exhaustion on Radius server
This thread has been viewed 32 times
  • 1.  Approaching radius ID exhaustion on Radius server
    Posted Feb 15, 2023 05:11 AM
    Hi all,
    I'm facing an issue that clients can't associate with a dot1x SSID because of Authentication timeout.
    There are a lot of dot1x timeout logs on the radius server as well as  "Approaching radius ID exhaustion on radius server socket xx" logs on the MCs
    Radsec is enabled on the Radius server.
    The radius server is working properly with branches (without these logs above). The HQ has more clients than other branches.
    The issue has happened since I upgraded MCs from AOS 8.8.0.3 to AOS 8.10.0.2.
    Does anyone have the same issue?
    Thank you in advance for your help
  • 2.  RE: Approaching radius ID exhaustion on Radius server
    Posted Feb 15, 2023 09:04 AM
    Are you using Radsec?  What is your radius server?
  • 3.  RE: Approaching radius ID exhaustion on Radius server
    Posted Feb 15, 2023 09:33 PM
    Hi Cjoseph,
    Yes, Radsec is enabled on the radius server. The Radius server is CPPM
    We have 2 MCs working in a cluster, and the authentication server group is load-balance with 2 CPPMs
    The issue has just happened with the headquarter, which has plenty of dot1x clients. There's no issue with the branches at the same time.
    Could you give me some advice?
    Thank you,
  • 4.  RE: Approaching radius ID exhaustion on Radius server
    Posted Feb 16, 2023 09:49 AM
    I believe this is bug AOS-235160.  It is fixed in 8.10.0.5 https://www.arubanetworks.com/techdocs/ArubaOS/Consolidated_8.x_RN/Content/8.10/05/resolved_8.10.0.5.htm
    "For some RADIUS servers during radsec socket clean up, incorrect handling of free sequence number count is observed in case of radius server timeout resulting in EAP ID exhaustion. The fix ensures that controllers work as expected. This issue was observed in controllers running ArubaOS 8.10.0.0 or later versions."
  • 5.  RE: Approaching radius ID exhaustion on Radius server
    Posted Mar 14, 2023 06:01 AM
    Hi Cjosepth,
    I upgraded MC to AOS 8.10.0.5, and there is no log "Approaching radius ID exhaustion on server" anymore.
    Thank you so much for your valuable advice.
    Thank you for your help
