APs are not showing in Virtual controller
  • 1.  APs are not showing in Virtual controller
    Posted Jul 01, 2018 11:39 AM
    I have configured MY APs on aruba central i am able to see the devices in Central login.
    Unfortunately i am getting 0 Access Points under local login virtual controller. this is happening for clients too.
    Everything is visible on central Not on Local Virtual controller login.
    If anyone had faced this issue and able to solve, please let me know what is the resolution.
    Sunil
  • 2.  RE: APs are not showing in Virtual controller
    Posted Jul 01, 2018 08:57 PM
    you can tryo to disable your Internet connection, and see if you can see your AP in VC ?
  • 3.  RE: APs are not showing in Virtual controller
    Posted Jul 05, 2018 05:31 AM
    Hi Sunil,
    Please share a screenshot for the issue being observed.
  • 4.  RE: APs are not showing in Virtual controller
    Posted Jul 09, 2018 01:07 AM
    Thanks for the kind reply... the issue has been resolved.
    Since I was logging the Aruba Console through slave IP address was not able to see the IAP and client details.
    Logged from Master IAP device IP address was able to see all the clients and AP details.
    Sunil
