APs Connected to Wired 802.1x Switch Port
  • 1.  APs Connected to Wired 802.1x Switch Port
    Posted Jan 30, 2012 08:21 PM
    We are trying to get rid of VMPS on our wired network and replace it with dot1x.  I was looking for a guide on how to get Aruba APs to authenticate to a Cisco doiing dot1x.  We only have 2950s so Mac Authentication Bypass is not supported.
    Can anyone point me in the right direction?
    Les
  • 2.  RE: APs Connected to Wired 802.1x Switch Port
    Posted Jan 30, 2012 08:35 PM
    What AOS are you running? You can go here and pick up a user guide based on the AOS you are running.
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=218
  • 3.  RE: APs Connected to Wired 802.1x Switch Port
    Posted Jan 30, 2012 09:23 PM
    @Les wrote:
    Les
    Les,
    You are in the right place at the right time.  Native wired 802.1x support for Aruba APs will be here sooner than you think.  Watch this space....
  • 4.  RE: APs Connected to Wired 802.1x Switch Port
    Posted Jan 31, 2012 02:44 PM
    Thanks for the responses.  I have check the User Guide for ArubaOS 5.0 and didn't find anything related to switch port access.
    What version of ArubaOS will have Native AP 802.1x?
  • 5.  RE: APs Connected to Wired 802.1x Switch Port
    Posted Jan 31, 2012 04:22 PM
    Version 6.1.3.0.  Coming out in the next day or so.
  • 6.  RE: APs Connected to Wired 802.1x Switch Port
    Posted Jan 31, 2012 08:49 PM
    Update: it is on the website now...
