AP´s getting dns request and then reboot
  • 1.  AP´s getting dns request and then reboot
    Posted Aug 20, 2013 12:37 PM
    Hi All
    I am testing a controller in a separate Vlan from my corporate network. This network is a simple ADSL router with DHCP and DNS.
    For somehow i get an IP address for the AP but it stucks then in ADP.
    It seems that dns can´t resolve aruba-master.. I don´t have access to that router to point IP of the controller to the name :(
    Can i resolve it by any other way ( like force AP to know that controller IP is 192.168.1.222
    Regards
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 192.168.1.13
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.1.1
    DHCP DNS server: 192.168.1.1
    DHCP DNS domain: local.lan
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master.local.lan to 192.168.1.1
  • 2.  RE: AP´s getting dns request and then reboot
    Posted Aug 20, 2013 12:58 PM
    If the Aruba Controller is on the same VLAN (192.168.1.222), the access point should be able to discover it, via broadcast.
    You can force it by breaking into the apboot> prompt  on the access point and typing:
    setenv master 192.168.1.222
    setenv serverip 192.168.1.222
    save
    boot
  • 3.  RE: AP´s getting dns request and then reboot
    Posted Aug 20, 2013 01:32 PM
    Hi
    cjoseph
    Force in the AP..
    Now it says:
    ARP Retry count exceeded; starting again
    DHCP broadcast 1
    Using eth0 device
    TFTP from server 192.168.1.222; our IP address is 192.168.1.13
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
  • 4.  RE: AP´s getting dns request and then reboot
    Posted Aug 20, 2013 01:44 PM
    Can stop the boot process of the AP and see if you can ping the controller? Or plug a laptop into that same port and try?
  • 5.  RE: AP´s getting dns request and then reboot
    Posted Aug 20, 2013 03:46 PM
    Hi All
    working...
    Only works with Controller port configured as  trunk.. if i put the port in access AP´s don´t go all the way
    I have the test router , dhcp and controller trunk on vlan 1
    Switch between as a valn segmentation for this on vlan 99
    Already check Vlan settings and ok
    Thanks for or help
