I have not tried it. If the documentation for your version tells it is supported, and it does not work, contact Aruba Support.
Before you do that, check the referred documentation that you only use the mentioned supported features.
Original Message:
Sent: Jul 07, 2021 01:34 AM
Subject: APs in Bridge Mode and external server (ClearPass) for Captive Portal authentication?
Hi
@Herman Robers, does the above still apply please? Captive portal is still not working when using bridge mode CAP?
Sara Zarb
Original Message:
Sent: Feb 03, 2021 06:21 AM
You can check the documentation here for what can be done. The documentation mentioned the feature added in ArubaOS 8.7.0.0.
Please note that Bridge mode is still deprecated in controller deployments, and unsupported with 30+ APs in a single broadcast domain. If you want to bridge traffic, Aruba Instant is the preferred choice.
Original Message:
Sent: Feb 02, 2021 05:16 PM
Is this still valid? My question is due to this information for 8.7.0:
Captive Portal Aruba OS now supports captive portal authentication for VAPs in the bridge forwarding mode. This feature is supported for wirelessusers on all Campus AP and RemoteAP models incluster and non-clustertopology. Tosupportcaptiveportalauthenticationinthebridgeforwardingmode,itisrequiredtoenabletheageout-bridge-userparameterintheaaaprofilecommand
Ivan Torres
Original Message:
Sent: Sep 14, 2015 06:03 AM
Captive portal in general is not possible in bridge mode.
Tim
