AP's in same subnet of users, or in other vlan?
  • 1.  AP's in same subnet of users, or in other vlan?
    Posted Nov 16, 2013 05:48 AM
    Hello all. I'll be planning an pilot wifi deployment in my company and I've got a doubt about best practices.
    Should I configure AP's in the same subnet of the users or get it in a mgmt vlan?
    To configure the AP's in the same subnet (10.1.172.0/22)
    10.1.172 .1 - .254 (for AP's)
    10.1.173.1- 174.254 (for users)
    But I was also thinkig to put the AP's in a different vlan, or a mgmt vlan
    10.1.63.1-254 (for AP's)
    10.1.172.1- 174.254 (for users)
    I'll be deploying a aruba 105 AP's
  • 2.  RE: AP's in same subnet of users, or in other vlan?
    Posted Nov 16, 2013 06:32 AM
    You want nothing to be in the same subnet as your users. They are two entirely different classes of devices and you want the flexibility to teach them differently.
  • 3.  RE: AP's in same subnet of users, or in other vlan?
    Posted Nov 18, 2013 10:23 AM
    This approach is valid for big and small deploys?
    In some sites I'll deploy 50 AP's for 300 users
    in other sites its just 1 AP for 20 users at the most.
  • 4.  RE: AP's in same subnet of users, or in other vlan?
    Posted Nov 18, 2013 10:37 AM
    It is much more important in larger deployments than in smaller ones. If you adhere to this principle when a network is small, if it grows suddenly, you won't have the problems associated with mixing wireless clients and other devices in the same network.
    I would say to keep it separate even with 50 access points.
  • 5.  RE: AP's in same subnet of users, or in other vlan?
    Posted Nov 18, 2013 06:34 PM
    I'll add that with separate subnets, whatever bad-thing happens to a client (whether defect or malicious) will be largely shielded from the management plane of your network -- whether that's one AP in a coffee-shop or 200+ in a large office.
    Much easier to troubleshoot when you can easily see which VLAN has the issue.
  • 6.  RE: AP's in same subnet of users, or in other vlan?
    Posted Nov 18, 2013 07:58 PM
    Msabin,
    Thank you for your insight.  I hope others chime in as well.
