AP's keeping rebooting on a Cisco 3560x
  • 1.  AP's keeping rebooting on a Cisco 3560x
    Posted Sep 24, 2012 02:02 PM
    We have upgraded a switch and started to move over the AP's (model 125). After about 2 minutes the switch log file shows the ports goes down then back up. I put it back to a Cisco 3560G and it is fine. Could this be because the 3560x is POE+?
  • 2.  RE: AP's keeping rebooting on a Cisco 3560x
    Posted Sep 24, 2012 03:57 PM
    Please make sure the AP125 is connected to port enet0.
    What version of code?
  • 3.  RE: AP's keeping rebooting on a Cisco 3560x
    Posted Sep 26, 2012 07:03 AM
    The code version we are running is 5.0.3.3.
    Yes, they are plugged into enet0.
  • 4.  RE: AP's keeping rebooting on a Cisco 3560x
    Posted Sep 26, 2012 09:08 AM
    If you type "show log system 50" the access points will say why they rebooted.  you can also plug a console cable into the back of the AP to see the console output to see why.
  • 5.  RE: AP's keeping rebooting on a Cisco 3560x
    Posted Oct 02, 2012 10:46 AM
    When I run , "show log system 50", it just tells me the Radio Stats and |fpapps| were either added or removed from a VLAN. I do not see anything telling about an AP down or rebooted.
    I cannot get to the console port on the back beacuse they are on/above the ceiling.
  • 6.  RE: AP's keeping rebooting on a Cisco 3560x
    Posted Oct 02, 2012 11:03 AM
    You have to do it while the AP is rebooting, because that log will roll over.  Try show log system all.  You might also want to open a support case in parallel.
