AP's on two different controllers.
  • 1.  AP's on two different controllers.
    Posted Jul 22, 2016 04:47 PM
    If I have an older WLC 6000 series one network and a 7210 on another.
    Then I have some existing AP's on the 6000 and I'm adding new 225's on the same network however I want them to join the 7210 controller.  I'm guessing I only have 3 ways:
    1) I console into each AP and specify the controller
    2) I let them join the old controller and then put them on the new one since the DHCP scope points to the old controller
    3) I create a new DHCP scope for the acces points and pointing DHCP option 43 to the new WLC.
  • 2.  RE: AP's on two different controllers.
    Posted Jul 22, 2016 05:03 PM
    Are both controllers in the same master/local cluster or are they separate masters?
  • 3.  RE: AP's on two different controllers.
    Posted Jul 22, 2016 08:31 PM
    They will both be Master I guess I'm new to Aruba's Master/Local/Cluster concept so bare with me here.
    I will be eventually decomissioning the older controller and the 7210 is going to take its place.  So I believe it would also be a separate Master.
  • 4.  RE: AP's on two different controllers.
    Posted Jul 22, 2016 09:11 PM
    Is one of the controllers providing DHCP for that VLAN the APs are on?
  • 5.  RE: AP's on two different controllers.
    Posted Jul 22, 2016 09:30 PM
    No controller won't be doing the DHCP.
  • 6.  RE: AP's on two different controllers.
    Posted Jul 22, 2016 09:51 PM
    Then either of the three options will work.
