APs showing down on controller, but they are up and pinging
  • 1.  APs showing down on controller, but they are up and pinging
    Posted Feb 22, 2012 07:43 PM
    I noticed today that one of our 3400 master controller is showing alot of APs as being down.  I checked Airwave and it shows them as up.  I am able to ping the APs even from the controller.
    Why is the controller showing them as being down?
    #3400
  • 2.  RE: APs showing down on controller, but they are up and pinging
    Posted Feb 22, 2012 08:44 PM
    -What version of code is this?
    - Is that controller a master or a local controller?
    - Do you see the APs as down on the commandline, GUI or both?
    - type "show ap bss-table" to see if those access points are even broadcasting.
  • 3.  RE: APs showing down on controller, but they are up and pinging
    Posted Feb 23, 2012 12:35 AM
    i've seen similar behaviour on a 3200 running 6.1.2.3 and it turned out that the DHCP server had exhausted the scope and the AP's were dropping off the controller and rebooting.
    I think there was some double allocation going on that was causing the erratic behaviour.
  • 4.  RE: APs showing down on controller, but they are up and pinging
    Posted Feb 23, 2012 11:18 AM
    *Version is 3.4.1.0
    *It's a Master
    *See them down on the CLI and GUI
    *APs that are down are not broadcasting, ones that are up are.
