APs status down
  • 1.  APs status down
    Posted Apr 30, 2014 03:37 AM
    Hello
    I know this is a common issue but I am really confused and trying to read all over the community but I have a weird behaviour
    I have two 3600 controllers and AP61 models, I am just testing on one controller to figure out why the APs not up all the time
    these are my configurations
    I have license installed and I've tried to restart the APs and Restart the controller many times
    ________________________________________________________________________
    (Master) #show run
    Building Configuration...
    version 3.3
    enable secret "******"
    hostname "Master"
    clock timezone MSK 3
    location "Building1.floor1"
    mms config 0
    controller config 76
    ip access-list eth validuserethacl
    permit any
    ip access-list session validuser
    any any any permit
    vpn-dialer default-dialer
    ike authentication PRE-SHARE ******
    user-role ap-role
    user-role denyall
    session-acl denyall
    user-role cpbase
    session-acl cpbase
    user-role guest-logon
    user-role guest
    user-role stateful-dot1x
    user-role logon
    aaa pubcookie-authentication
    interface mgmt
    shutdown
    vlan 10
    vlan 14 "14"
    vlan 16 "16"
    vlan 18 "18"
    interface gigabitethernet 1/0
    description "GE1/0"
    trusted
    speed 1000
    duplex full
    switchport mode trunk
    switchport access vlan 18
    interface gigabitethernet 1/1
    description "GE1/1"
    trusted
    interface gigabitethernet 1/2
    description "GE1/2"
    trusted
    speed 1000
    duplex full
    switchport trunk allowed vlan 1,10,14,16,18
    interface gigabitethernet 1/3
    description "GE1/3"
    trusted
    interface vlan 1
    ip address 172.16.0.253 255.255.0.0
    interface vlan 16
    ip address 10.16.1.20 255.255.0.0
    interface vlan 14
    ip address 10.14.1.20 255.255.0.0
    interface vlan 18
    ip address 10.18.1.20 255.255.0.0
    interface vlan 10
    ip address 10.10.32.1 255.255.255.0
    ip default-gateway 10.18.1.1
    wms
    general poll-interval 60000
    general poll-retries 3
    general ap-ageout-interval 30
    general sta-ageout-interval 30
    general learn-ap disable
    general persistent-known-interfering enable
    general propagate-wired-macs enable
    general stat-update enable
    general collect-stats disable
    no crypto isakmp psk-caching
    no crypto-local isakmp permit-invalid-cert
    localip 0.0.0.0 ipsec f6dcd11c7cddbb64279f3a34d64ec43c4c1e0e0fe94896d2
    crypto isakmp groupname changeme
    crypto-local isakmp dpd idle-timeout 22 retry-timeout 2 retry-attempts 3
    crypto-local isakmp xauth
    vpdn group l2tp
    ppp authentication PAP
    ip dhcp pool aa
    default-router 10.18.1.20
    dns-server 8.8.8.8
    domain-name test.com
    lease 1 0 0
    network 10.18.2.0 255.255.255.0
    authoritative
    service dhcp
    vpdn group pptp
    ppp authentication MSCHAPv2
    mux-address 0.0.0.0
    adp discovery enable
    adp igmp-join enable
    adp igmp-vlan 0
    ssh mgmt-auth username/password
    mgmt-user admin root 1583f9c201c90ca785b2df96aa7e4baa7fdd720ba5cd92e7bd
    no database synchronize
    database synchronize rf-plan-data
    ip mobile domain default
    ip igmp
    packet-capture-defaults tcp disable udp disable sysmsg disable other disable
    ip domain lookup
    country SA
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
    auth-server Internal
    aaa profile "abc-aaa-profile"
    initial-role "cpbase"
    authentication-dot1x "default"
    aaa profile "default"
    aaa profile "TEST-aaa-profile"
    aaa profile "TESTT-aaa-profile"
    aaa authentication captive-portal "default"
    aaa authentication vpn
    aaa authentication mgmt
    aaa authentication stateful-dot1x
    aaa authentication wired
    web-server
    ap system-profile "default"
    ap regulatory-domain-profile "default"
    country-code SA
    valid-11g-channel 1
    valid-11g-channel 6
    valid-11g-channel 11
    valid-11a-channel 36
    valid-11a-channel 40
    valid-11a-channel 44
    valid-11a-channel 48
    valid-11a-channel 52
    valid-11a-channel 56
    valid-11a-channel 60
    valid-11a-channel 64
    valid-11a-channel 149
    valid-11a-channel 153
    valid-11a-channel 157
    valid-11a-channel 161
    valid-11a-channel 165
    valid-11g-40mhz-channel-pair 1+
    valid-11g-40mhz-channel-pair 5-
    valid-11g-40mhz-channel-pair 7+
    valid-11g-40mhz-channel-pair 11-
    valid-11a-40mhz-channel-pair 36+
    valid-11a-40mhz-channel-pair 40-
    valid-11a-40mhz-channel-pair 44+
    valid-11a-40mhz-channel-pair 48-
    valid-11a-40mhz-channel-pair 52+
    valid-11a-40mhz-channel-pair 56-
    valid-11a-40mhz-channel-pair 60+
    valid-11a-40mhz-channel-pair 64-
    valid-11a-40mhz-channel-pair 149+
    valid-11a-40mhz-channel-pair 153-
    valid-11a-40mhz-channel-pair 157+
    valid-11a-40mhz-channel-pair 161-
    ap wired-ap-profile "default"
    ap enet-link-profile "default"
    ap snmp-profile "default"
    ids general-profile "default"
    ids unauthorized-device-profile "default"
    ids profile "default"
    rf arm-profile "default"
    rf optimization-profile "default"
    rf event-thresholds-profile "default"
    rf dot11a-radio-profile "default"
    rf dot11g-radio-profile "default"
    wlan ht-ssid-profile "abc-ht-ssid-profile"
    wlan ht-ssid-profile "default"
    wlan ht-ssid-profile "TEST-ht-ssid-profile"
    wlan ht-ssid-profile "TESTT-ht-ssid-profile"
    wlan ssid-profile "abc-ssid-profile"
    essid "abc"
    wlan ssid-profile "default"
    wlan ssid-profile "TEST-ssid-profile"
    essid "TEST"
    wlan ssid-profile "TESTT-ssid-profile"
    essid "TESTT"
    wlan virtual-ap "abc-vap-profile"
    vlan 18
    aaa-profile "abc-aaa-profile"
    wlan virtual-ap "default"
    wlan virtual-ap "TEST-vap-profile"
    vlan 18
    aaa-profile "TEST-aaa-profile"
    wlan virtual-ap "TESTT-vap-profile"
    vlan 18
    aaa-profile "TESTT-aaa-profile"
    ap-group "default"
    end
    _______________________________________________________________________________________
    Please advice me how to troubleshoot this
    Thanks in advanced
    Regards
    #3600
  • 2.  RE: APs status down
    Posted Apr 30, 2014 03:57 AM
    I tried to access apboot but whenever I access the "Hit <Enter> to stop autoboot: 0 " it goes to acboot instead of apboot
    how can I change this too ?
