Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
aps status down on controller but they working
  • 1.  aps status down on controller but they working
    Posted Sep 08, 2016 07:29 AM
    Hi guys ! aps status down on controller but they working .
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    70:3a:0e:c6:26:0e MARXAL 205 172.17.101.163 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:12 MARXAL 205 172.17.101.195 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:18 MARXAL 205 172.17.101.189 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:1a MARXAL 205 172.17.101.133 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:20 MARXAL 205 172.17.101.191 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:22 MARXAL 205 172.17.101.122 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:24 MARXAL 205 172.17.101.126 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:28 MARXAL 205 172.17.101.188 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:2a MARXAL 205 172.17.101.190 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:2c MARXAL 205 172.17.101.143 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:32 MARXAL 205 172.17.101.130 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:34 MARXAL 205 172.17.101.193 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:36 MARXAL 205 172.17.101.199 Up 23h:23m:17s 172.17.101.51 172.17.101.50
    70:3a:0e:c6:26:3c MARXAL 205 172.17.101.134 Down S 0.0.0.0 0.0.0.0
    70:3a:0e:c6:26:3e MARXAL 205 172.17.101.139 Down S 0.0.0.0 0.0.0.0
    (MHARUBA01) #ping 172.17.101.163
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 172.17.101.163, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.137/0.1882/0.361 ms
  • 2.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 07:50 AM
    What is the output of "show ap bss-table"?  It is possible that those APs are on a different controller.  If there is no output to the bss-table, the APs are not broadcasting.  If this is a local you are running your command on, it will only have visibility about APs that terminate on that local.  You should run your "show ap database" command on the master controller for better visibility.
  • 3.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 08:12 AM
    APs are connected local controller but they not working i want APs worked ,yesterday Aps worked , when i tried config VRRP , Controller after then it all went wrong
  • 4.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 08:37 AM
    Whatever configuration change you made, you should reverse it.  I thought your first post said that the APs were working.
  • 5.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 08:48 AM
    I reversed it but Aps not working , Ping is working  but they can not see the controller (
  • 6.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 09:12 AM
    Did it work before?  If it did, it is probably best that you get TAC to look at your configuration and advise you...
  • 7.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 09:27 AM
    Yes  aps  worked , at the moment 70 is  working  of 105 .
  • 8.  RE: aps status down on controller but they working
    Posted Sep 08, 2016 10:06 AM
    Aps it worked after I changed the settings on the controller and the controller Local reconfigured as a master standby , but uplinks on Master standby not working
