ap's status is "denied" ?
This thread has been viewed 52 times
  • 1.  ap's status is "denied" ?
    Posted Dec 07, 2011 01:38 PM
    Has anyone ever come across an ap in the ap database that says denied?
    #show ap database
    AP Database
    Name               Group    AP Type  IP Address     Status  Flags  Switch IP
    00:0b:86:cf:d1:15  default  105      10.20.100.208  Denied         10.20.0.180
    00:0b:86:cf:d1:17  default  105      10.20.100.210  Denied         10.20.0.180
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; H = Using 802.11n license; D = Dirty or no config
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP; 2=Using IKE version 2
           M = Mesh node; Y = Mesh Recovery
    Total APs:2
  • 2.  RE: ap's status is "denied" ?
    Posted Dec 07, 2011 01:39 PM
    I am going to guess that has something to do with CPS (Control Plane Security). Do you have CPS enabled?
  • 3.  RE: ap's status is "denied" ?
    Posted Dec 07, 2011 01:43 PM
    Out of the box controller.
    All that was done is:
    initial config (ip, mask, gw)
    licenses installed.
    Code upgraded to 6.1.2.5
    So no I don't have CPS unless it was turned on by default.
  • 4.  RE: ap's status is "denied" ?
    Posted Dec 07, 2011 01:46 PM
    Pretty sure it is enabled by default.
  • 5.  RE: ap's status is "denied" ?
    Posted Dec 07, 2011 01:53 PM
    If the controller had 6.x code on it from the factory then CPSec IS on by DEFAULT
  • 6.  RE: ap's status is "denied" ?
    Posted Dec 07, 2011 02:01 PM
    I have fixed the issue.
    Cleared the ap from the database. Rebooted the ap.
    Up acts normal now.
    Ok so in 6.1 CPS is on.
    Nope no denied here:
    Would be helpful if DEV is going to use a flag to give us an idea what it does.
  • 7.  RE: ap's status is "denied" ?
    Posted Feb 13, 2012 12:37 PM
    Agreed.
  • 8.  RE: ap's status is "denied" ?
    Posted Feb 13, 2012 06:16 PM
    Up acts normal now.
    You get much more than a flag.  You get a big denied when an AP is denied:
    (host) #show ap database
    AP Database
    00:0b:86:66:97:46  default  RAP-5WN  192.168.1.248  Down              192.168.1.3
    00:24:6c:c2:97:1b  default  105      192.168.1.240  Down              192.168.1.3
    00:24:6c:cb:30:89  default  105      192.168.1.238  Down              192.168.1.3
    00:24:6c:cb:30:94  default  105      192.168.1.239  Down              192.168.1.3
    00:24:6c:cb:30:ba  default  105      192.168.1.245  Down              192.168.1.3
    AP105              default  105      192.168.1.251  Down       M      192.168.1.3
    AP135              default  135      192.168.1.251  Up 10m:8s  2      192.168.1.3
    d8:c7:c8:c1:66:ab  default  105      192.168.1.242  Down              192.168.1.3
    GOC-SHP1-AP125     default  125      192.168.1.243  Denied            192.168.1.3
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    Total APs:9
  • 9.  RE: ap's status is "denied" ?
    Posted Feb 22, 2012 01:06 PM
     Denied is not a Flag, it is Status like up or down or upgrading.
  • 10.  RE: ap's status is "denied" ?
    Posted Apr 26, 2012 05:16 PM
    I had same problem, I disabled CPSec and My APs came back up
  • 11.  RE: ap's status is "denied" ?
    Posted Oct 19, 2012 10:24 AM
    Me too did the same... I disabled CPSec and My APs came back up... is it normal?
  • 12.  RE: ap's status is "denied" ?
    Posted Oct 19, 2012 03:20 PM
    If you have CPSEC enabled, you need to allow all certs or you have to manually certify each AP into the CAP whitelist.
  • 13.  RE: ap's status is "denied" ?
    Posted May 29, 2017 07:02 PM
    Actually I have a Controller 7205 with image version ArubaOS 6.4.3.4
    And the state is DENIED
    (Controller_Aruba7205) #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    AUDITORIO default 225 172.16.0.2 Down 172.16.0.254 0.0.0.0
    PRESIDENCIA default 215 172.16.0.3 Denied 172.16.0.254 0.0.0.0
    So the Option CPsec was disable on the Controller, but the FLAG is I (Inactive). Then the AP was provisioned and the AP is not ACTIVE, with the command SHOW AP ACTIVE (AP = 0)
    Thanks for your help.
  • 14.  RE: ap's status is "denied" ?
    Posted May 29, 2017 09:25 PM
    You should reboot the denied AP, because it will not resolve itself unless you reboot it.
  • 15.  RE: ap's status is "denied" ?
    Posted May 30, 2017 12:44 PM
    Thanks Colin.
    However, the problem continues.
    Aruba Controller has version: ArubaOS 6.4.3.4
    AP  225: 6.4.2.
    Disable the CPSEC option on the controller and then the AP will reboot.
    Then provision the AP with the WIZARD. I have everything in VLAN 1 and the default IP address 172.16.0.0/24.
    And I still have the Flag of I:
    AP Database
    AUDITORIO default 225 172.16.0.2 Up 11m:22s I 172.16.0.254 0.0.0.0
    Therefore the AP does not appear to me active:
    _Aruba7205) #show ap active
    Active AP Table
    Name Group IP Address 11g Clients 11g Ch/EIRP/MaxEIRP 11a Clients 11a Ch/EIRP/MaxEIRP AP Type Flags Uptime Outer IP
    Num APs:0
    Regards
  • 16.  RE: ap's status is "denied" ?
    Posted May 30, 2017 12:46 PM
    Do you have any other ip addresses configured on controller interfaces?
    Do you have an LMS-IP configured anywhere?
  • 17.  RE: ap's status is "denied" ?
    Posted May 30, 2017 12:50 PM
    Hi Colin
    It is a new implementation, the computers are new, they have a default configuration.
    Aruba7205 #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol
    vlan 1 172.16.0.254 / 255.255.255.0 up up
    loopback unassigned / unassigned up up
    mgmt unassigned / unassigned up down
    Aruba7205#show controller-ip
    Switch IP Address: 172.16.0.254
    Switch IP is from Vlan Interface: 1
    Switch IPv6 address is not configured.
    The AP is on the Port Gi0/0/2, in VLAN 1 for Administration.
    Aruba7205) #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    1 Default GE0/0/0-0/3 GE0/0/4-0/5 Pc0-7 N/A
  • 18.  RE: ap's status is "denied" ?
    Posted May 30, 2017 01:05 PM
    That AP has an "I", not a D flag.  An I could mean that you have not defined any WLAN so it is inactive, or you have a profile issue that is keeping the AP from coming up.  I would type "show profile-errors" to see if you have anything that could be a problem.  I would also type "show log system 50" to see if there is anything else obvious.
  • 19.  RE: ap's status is "denied" ?
    Posted May 30, 2017 01:13 PM
    Thanks Colin.
    I attach the outputs on file.
    Additionally the LEDs of both radios are in amber.
    Regards
    Attachment(s)
    txt
    DeploymentAruba7205.txt   5 KB 1 version
  • 20.  RE: ap's status is "denied" ?
    Posted May 30, 2017 01:21 PM
    Is CPSEC enabled or disabled?
    May 30 02:15:49 :311020:  <ERRS> |AP AUDITORIO@172.16.0.2 sapd|  An internal system error has occurred at file sapd_redun.c function redun_retry_tunnel line 4488 error redun_retry_tunnel: Switching to clear. Error:RC_ERROR_CPSEC_DENIED. Ipsec not successful after reboot.
  • 21.  RE: ap's status is "denied" ?
  • 22.  RE: ap's status is "denied" ?
    Posted May 30, 2017 01:29 PM
    Where does it say on your controller that it is disabled?  Screenshot please.
  • 23.  RE: ap's status is "denied" ?
    Posted May 30, 2017 01:37 PM
    By default CPsec was enabled, however I did it as a test.
    In Configuration / AP Installation / Whitelist / Control Plane Sec / Disabled
  • 24.  RE: ap's status is "denied" ?
    Posted May 30, 2017 02:20 PM
    I would open a tac case to see what other things could be causing your issue.
  • 25.  RE: ap's status is "denied" ?
    MVP EXPERT
    Posted May 30, 2017 03:05 PM
    Just one further step you can try whilst waiting for TAC is to console into the AP and perform a "clear os, save, boot" to factory reset the AP.
  • 26.  RE: ap's status is "denied" ?
    Posted May 31, 2017 12:25 PM
    Muchas gracias a todos por sus aportes.
    Les comparto los resultados con otra Controladora 7010
    1. Venía con un reset default, le configure los parámetros por defecto, VLAN 1, 172.16.0.254/24 (IP Controller), y adicionalmente habilite el DHCP Server con el Pool 172.16.0.0/24
    2. Todos los puertos en VLAN
    3. Así que conecte con un cable de conexión directa del puerto 0 del Controller hacia el Puerto ENET del AP 215. (Previamente, había pasado el IAP a CAP, validando desde CLI que se tuviera conectividad hacia el IP 172.16.0.254
    4. Una vez conectado, revise con el comando SHOW AP DATABASE, y se indicaba el Status DENIED. (Investigue y explicaban que ese estado se debe a que esta habilitado por defecto CPsec)
     Referencia Item 4.
    https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/867
    5. Así que en la Controladora aplique la recomendación del URL, que es dejar habilitado CPsec y luego agregar manualmente el AP a lista blanca: (AP tiene MAC terminada en: BB 3A)
    Configuration / AP Instala / Whitelist. Agregue el AP con Cert Type: Factory-cert & State: Certified-factory-cert.
    6. El AP se reinicia y posteriormente ya aparece el
    (Controller_Aruba7010) #show ap database
    AP Database
    PRESIDENCIA  default  215      172.16.0.2  Up 12m:40s  2I     172.16.0.254  0.0.0.0
    7. Luego procedi a aprovisionarlo via GUI
    Configuration / AP Installation / Provision
    8. Una vez aprovisionado y que se aplica y manda a reiniciar, valide con el comando SHOW AP ACTIVE, para validar que estuviera activo, sin embargo no lo esta.
    (Controller_Aruba7010) #show ap active
    Active AP Table
    Num APs:0
  • 27.  RE: ap's status is "denied" ?
    Posted Jul 05, 2017 12:55 PM
  • 28.  RE: ap's status is "denied" ?
    Posted Jul 05, 2017 03:03 PM
    Did you open a TAC case?  It has been over a month..
