AP's Wont broadcast wifi
  • 1.  AP's Wont broadcast wifi
    Posted Aug 12, 2013 10:34 AM
    I have AP's on 2 3200 controllers that are showing identical behavior. They light up saying they are connected to the controller but they wont broadcast a signal. What I have noticed is that if I reduce the number of active AP's to equal the number of wireless intrusion licenses everything works great. Once a start up one more ap than I have intrusion licenses then that radio wont work. I currently have more AP licenses than I do Intrusion licenses on each controller. Will adding intrusion licenses fix this issue or am I missing something?
    #3200
  • 2.  RE: AP's Wont broadcast wifi
    Posted Aug 12, 2013 10:39 AM
    Licensing is calculated by the lowest applied license. So if you have 25 RFProtect and 50 AP licenses, only 25 AP's will be able to come up.
  • 3.  RE: AP's Wont broadcast wifi
    Posted Aug 12, 2013 10:41 AM
    That is what I figured. I have an open order to aruba for Intrusion licenses. I hope to have them soon. Thanks for the confirmation.
  • 4.  RE: AP's Wont broadcast wifi
    Posted Aug 12, 2013 10:52 AM
    If you have an Aruba licensing account, you can create a temp license to hold you over until you get your real licenses.
  • 5.  RE: AP's Wont broadcast wifi
    you are limited to the lowest license total.   since you have more AP licenses; you are limited to the number of RFProtect licenses in your case.
    run the following to see your allowances; look for the "Overall AP License Limit" field.
    show ap license-usage
  • 6.  RE: AP's Wont broadcast wifi
    That?s the way the Aruba licensing works. The AP count will be limited to the smallest of the AP, PEF (of PEF-NG) or WIP (or RFP) license installed.
