APs/Devices display Configuration Error on all APs for all sites.
  • 1.  APs/Devices display Configuration Error on all APs for all sites.
    Posted Jan 19, 2020 03:18 AM
    In Airwave, all APs in a site folder show "Error" under the Configuration column.  When I select an AP and check the manage page, this error shows on the "Configuration:" item:
    Error (Telnet/SSH Error: (pattern match timed-out) in password failure: Permission denied, please try again. )
    Where do I set these credentials?  In the controller configuration? Is so where? We are running three instances of Airwave.  Instances 1 & 2 do not have this problem.  Instance 3 does.  There are multiple controllers per instance, yet instance 3 is the only one that has this problem.
  • 2.  RE: APs/Devices display Configuration Error on all APs for all sites.
    MVP EXPERT
    Posted Jan 20, 2020 03:43 AM
    Are the APs in question Aruba APs which are terminating on a controller? If so, you need to set the Telnet/SSH username and password in AirWave.
    Locate the Mobility Controllers Device Communication area on the Devices > Manage page, Enter the credentials to be used to manage the device.
