Are AP93 Compatibile with the Aruba 2400 Controller??
  • 1.  Are AP93 Compatibile with the Aruba 2400 Controller??
    Posted May 01, 2013 03:53 PM
    Are the AP93's compatibile with the Aruba 2400 Controller??
    Are there any disadvantages of buying an older controller?
    Thanks!
  • 2.  RE: Are AP93 Compatibile with the Aruba 2400 Controller??
    Posted May 01, 2013 11:39 PM
    Hello
    Yes its compatible... but you need a minimum firmware of 5.0.4.2
    Yes the disasvantage is that the lastest supported release is release 5
    As far i remenber the end of life of this product for support is on 2016.... after that you will not have support...
    This is an old controller i recommend you get a new one
    You can check yourself that info on the relase notes of the ap 93 and on the end of life list on arubanetworks page
    Hope it helps
