I've been digging around and found this post regarding CP guides...https://community.arubanetworks.com/t5/Security/ClearPass-Docs-Configuration-amp-Integration-Guides-Solution/m-p/522283
I need to download these and access them while offline. The print pdf button on the support site only allows me to print a single page at a time. Any suggestions??
Here is a link to the 6.8 user guide PDF on the Aruba site, not sure how it maps though because you can not navigate to it on the support site...
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_ViewDetails/Default.aspx?EntryId=36346
Thanks for the link. I did use the download button that was on the page, but it ask me to login and will not accept my partner portal credentials.
Many of the ClearPass Guides should be available in asp.arubanetworks.com without a login:
https://asp.arubanetworks.com/downloads;fileTypes=DOCUMENT;products=Aruba%20ClearPass%20Policy%20Manager%20%28CPPM%29
Thanks for the link. I tried downloading documents and was redirected to https://www.arubanetworks.com/techdocs/ClearPass/6.9/Guest/Content/home.htm or to a page where you can download a page at a time.
then I think it will likely be easier to use the new portal we're moving to,
no credentials required to download DOC's
DOC's and links to HTML versions of User Guides, Release-Notes on this page https://community.arubanetworks.com/t5/Security/ClearPass-Docs-Configuration-amp-Integration-Guides-Solution/m-p/522283
which can also be found from https://www.arubanetworks.com/clearpassdocs are CPPM specific.
However you should be able to download them locally as PDF's, we've moved DOC's from the old support site {ASC} to the new support portal ASP asp.arubanetworks.com, going forward ASP should be your central place for User guides, Release-Notes, TechNotes etc.
