Hi all,
My superior is planning to change the management IP of ClearPass.
Thus as per title above, are current onboarded users require to re-onboard after we changed the management IP of Clearpass?
Thanks.
EAP-TLS is based on a certificate, no an ip address... If you are doing OCSP to check revocation you might need to make sure that your OCSP settings are looking at the right ip address/hostname to check revocation
