Ariwave/VC Password changes cuased missmatch
  • 1.  Ariwave/VC Password changes cuased missmatch
    Posted Mar 31, 2016 11:14 AM
    So we have Airwave up and running.  The contractor left the defualt passwords so I changed the Airwave AMP GUI password and then recently discovered that the VC was accessible via instant.arubenetworks.com and was using the default password as well. Since changing this password I know have a mismatch for the mgmt-user admin  ........
    How do I correct this and were.  I assume its the template I have to correct. Our template is currently named the based on the IAP IOS that was installed by the contractor.   What steps should I take make this correction without cuasing havoc.
  • 2.  RE: Ariwave/VC Password changes cuased missmatch
    Posted Mar 31, 2016 11:21 AM
    You should probably contact TAC in parallel ASAP.  The sequence of whatever steps you took could leave you exposed and you should get that addressed immediately.
