ARM: No Free Channels
  • 1.  ARM: No Free Channels
    Posted Nov 27, 2017 08:24 AM
    On controller running 6.5.3.3 the ARM rf-summary shows no free channels. On another controller running 6.4.4.16 I can see 18 free 5Ghz channels and 2 free 2.4Ghz channels.
    #show ap arm rf-summary ap-name AAP-W******02
    Channel Summary
    channel retry phy-err mac-err noise util(Qual) cov-idx(Total) intf_idx(Total)
    36 0 0 0 93 8/7/0/0/90 0/0(0) 6/0//0/0(6)
    40 0 0 0 93 11/0/1/0/90 0/0(0) 1/2//0/0(3)
    44 0 0 0 93 11/0/1/0/90 0/0(0) 0/0//0/0(0)
    48 0 0 0 93 19/8/1/0/90 0/0(0) 1/0//0/0(1)
    52 3 0 0 93 2/0/0/0/91 6/0(6) 0/0//0/0(0)
    56 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    60 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    64 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    100 0 0 0 93 0/0/0/0/91 0/0(0) 0/0//0/0(0)
    104 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    108 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    112 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    116 0 0 0 93 9/0/0/0/91 0/0(0) 12/8//0/0(20)
    120 0 0 0 93 9/0/0/0/91 5/0(5) 25/0//0/0(25)
    124 0 0 0 93 9/0/0/0/91 0/0(0) 0/8//0/0(8)
    128 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    132 0 0 0 93 0/0/0/0/91 0/0(0) 0/0//0/0(0)
    136 0 0 0 93 9/0/0/0/91 0/0(0) 0/0//0/0(0)
    140 0 0 0 96 0/0/0/0/91 6/0(6) 0/0//0/0(0)
    1 0 0 0 89 0/0/0/0/85 0/0(0) 4/2//5/1(12)
    6 7 0 6 94 11/9/0/0/89 0/0(0) 13/4//4/1(22)
    11 0 0 0 90 79/66/1/6/88 4/0(4) 27/0//4/1(32)
    Columns:util(Qual): ch-util/rx/tx/ext-ch-util/quality
    Noise followed by "*" indicates that the last scan on this channel was a split-scan, which was
    triggered by high channel noise. Check show ap arm split-scan-history.
    HT/VHT Channel Summary
    Bandwidth Channel range Total interference index
    40MHz 116-120 45
    40MHz 52-56 0
    40MHz 100-104 0
    40MHz 124-128 8
    40MHz 36-40 9
    40MHz 60-64 0
    40MHz 108-112 0
    40MHz 132-136 0
    40MHz 44-48 1
    Interface Name :wifi0
    Current ARM Assignment :52+/18.0
    Covered channels a/g :18/0
    Free channels a/g :0/0
    ARM Edge State :enable
    Last check channel/pwr :6m:52s/5m:2s
    Last change channel/pwr :13m:13s/15m:1s
    Next Check channel/pwr :40s/2m:16s
    Assignment Mode :Single Band
    Interface Name :wifi1
    Current ARM Assignment :6/9.0
    Covered channels a/g :0/3
    Last check channel/pwr :6m:44s/46s
    Last change channel/pwr :4h:9m:2s/4h:9m:2s
    Next Check channel/pwr :1m:5s/5m:44s
    Is this a known issue in this code revision or someother problem?
  • 2.  RE: ARM: No Free Channels
    Posted Nov 27, 2017 09:31 AM
    That is a per-AP counter that determines how many channels have no APs on them as a possible destination.  It could vary depending on density and it potentially could be different for every AP on the same controller.
  • 3.  RE: ARM: No Free Channels
    Posted Nov 27, 2017 09:52 AM
    I understand that the values could vary between different APs depending on the RF environment. What I don't understand is why in this case when so many channels have an interference index of 0 and high quality they aren't being counted as free channels. Is this what you would expect?
  • 4.  RE: ARM: No Free Channels
    Posted Nov 27, 2017 10:23 AM
    It is possible that those channels have not been scanned enough times to determine that.
    Have you seen the document here?  https://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/7592/1/ARM%20Doc%20Supplement.pdf
    It might not answer your question specifically, but it would give you an idea in general how ARM works.
  • 5.  RE: ARM: No Free Channels
    Posted Dec 26, 2017 07:29 PM
    @rossdrossd i also see the same, did you take this further and get it confirmed as a bug ?
  • 6.  RE: ARM: No Free Channels
    Posted Jan 03, 2018 05:27 AM
    @dugem2016 no I haven't progressed this. Colin's last suggestion was to wait longer but after 27 days the a/g free channels are still showing as 0/0. I'm less concerned as ARM has chosen sensible channels rather than them all being the same when I originally posted.
  • 7.  RE: ARM: No Free Channels
    Posted Jan 03, 2018 07:36 AM
    indeed too in my case arm is still choosing to move around when provoked to do so, but the free count should not be 0/0 as far as i can tell.
  • 8.  RE: ARM: No Free Channels
    MVP EXPERT
    Posted Jan 03, 2018 08:03 AM
    What AP model is this and the regulatory domain set to for the AP? I've seen there where AP's haven't been supported in a regulatory domain.
    Try the below to determine what channels are allowed in the country.
     show ap allowed-channels <country-code>
  • 9.  RE: ARM: No Free Channels
    Posted Jan 04, 2018 08:44 PM
    @zalion, I think it's something other than the regdomain - i tested this on ap215, ap315, ap92, ap135 in a domain that is a first level regdomain
