ARM not working?
This thread has been viewed 26 times
  • 1.  ARM not working?
    Posted Mar 12, 2024 10:26 AM
    I started investigating a problem in Aruba system (many adjacent AP use the same 5GHz channel) and noticed an interesting thing about the ARM statistics. By issuing the "show ap arm rf-summary ap-name" command for each AP, I see that the "Last Check Channel/pwr" and "Last Change Channel/pwr" are almost equal to the AP uptime. Using the "show ap arm history ap-name" command, the history was empty for each AP I checked.
    Is this normal? I don't think this is how it should work. What could be the problem, what can I check? In ARM settings everything is on default.
    MMs in the DC, MD clusters on sites, running software AOS 8.10.0.10
    (WLC1) [MDC] *#show ap active | include xxx-xxx-AP09
    xxx-xxx-AP09  xxx_xxx      10.xx.x.xxx  534      A2a    13d:18h:54m:32s  N/A       A                      AP:5GHz-HE:40-/19.0/23.0/2            AP:2.4GHz-HE:11/12.0/20.0/0
    (WLC1) [MDC] *#show ap arm rf-summary ap-name xxx-xxx-AP09
    Channel Summary
    phy-type  channel  retry  phy-err  mac-err  noise  util(Qual)     cov-idx(Total)  intf_idx(Total)
    5GHz      36       0      0        0        92     4/0/3/0/99     0/0(0)          12/9//0/0(21)
    5GHz      40       3      0        5        94     9/5/3/0/99     6/0(6)          24/0//0/0(24)
    5GHz      44       0      0        0        92     4/1/3/0/100    0/0(0)          6/13//0/0(19)
    5GHz      48       0      0        0        92     13/9/3/0/99    0/0(0)          14/7//0/0(21)
    5GHz      52       0      0        0        92     2/2/0/0/100    0/0(0)          23/7//0/0(30)
    5GHz      56       0      0        0        92     1/1/0/0/100    0/0(0)          17/10//0/0(27)
    5GHz      60       0      0        0        92     3/2/0/0/99     0/0(0)          14/6//0/0(20)
    5GHz      64       0      0        0        92     0/0/0/0/100    0/0(0)          13/3//0/0(16)
    5GHz      100      0      0        0        92     0/0/0/0/100    0/0(0)          17/12//0/0(29)
    5GHz      104      0      0        0        92     0/0/0/0/100    7/0(7)          35/5//0/0(40)
    5GHz      108      0      0        0        92     1/1/0/0/100    3/0(3)          16/12//0/0(28)
    5GHz      112      0      0        0        92     1/0/0/0/99     0/0(0)          8/5//0/0(13)
    5GHz      116      0      0        0        92     0/0/0/0/100    0/0(0)          13/9//0/0(22)
    5GHz      120      0      0        0        92     13/12/0/0/99   3/0(3)          26/7//0/0(33)
    5GHz      124      0      0        0        92     0/0/0/0/100    4/0(4)          22/10//0/0(32)
    5GHz      128      0      0        0        92     4/3/0/0/99     0/0(0)          14/10//0/0(24)
    5GHz      132      0      0        0        92     10/9/0/0/99    0/0(0)          13/3//0/0(16)
    5GHz      136      0      0        0        92     6/5/0/0/99     0/0(0)          12/3//0/0(15)
    5GHz      140      0      0        0        92     0/0/0/0/100    0/0(0)          0/2//0/0(2)
    2.4GHz    1        0      0        0        94     72/39/19/0/86  14/13(27)       138/45//115/13(311)
    2.4GHz    6        0      0        0        94     63/39/18/0/94  18/8(26)        160/72//55/46(333)
    2.4GHz    11       0      0        4        96     16/5/8/0/97    8/6(14)         127/39//62/8(236)
    Columns:util(Qual): ch-util/rx/tx/ext-ch-util/quality
    Noise followed by "*" indicates that the last scan on this channel was a split-scan, which was
    triggered by high channel noise. Check show ap arm split-scan-history.
    HT/VHT Channel Summary
    Phy-Type  Bandwidth  Channel range  Total interference index
    5GHz      40MHz      116-120        55
    5GHz      40MHz       52-56         57
    5GHz      40MHz      100-104        69
    5GHz      40MHz      124-128        56
    5GHz      40MHz       36-40         45
    5GHz      40MHz       60-64         36
    5GHz      40MHz      108-112        41
    5GHz      40MHz      132-136        31
    5GHz      40MHz       44-48         40
    5GHz      80MHz      116-128        111
    5GHz      80MHz       52-64         93
    5GHz      80MHz      100-112        110
    5GHz      80MHz       36-48         85
    Interface Name           :wifi0
    Phy-Type                 :5GHz
    Current ARM Assignment   :40-/19.0
    Covered channels 5/2.4GHz     :16/0
    Free channels 5/2.4GHz        :0/0
    ARM Edge State           :enable
    Last check channel/pwr   :13d:15h:44m:29s/13d:15h:44m:29s
    Last change channel/pwr  :13d:15h:44m:29s/13d:15h:44m:29s
    Next Check channel/pwr   :0s/0s
    Assignment Mode          :Single Band
    Interface Name           :wifi1
    Phy-Type                 :2.4GHz
    Current ARM Assignment   :11/12.0
    Covered channels 5/2.4GHz     :0/3
    ARM Edge State           :disable
    (WLC1) [MDC] *#
    Thanks!
  • 2.  RE: ARM not working?
    Posted Mar 12, 2024 10:53 AM
    Since your controller is managed by a Mobility Conductor (MCR), your environment is using AirMatch and not ARM.
    Carson Hulcher, ACEX#110
  • 3.  RE: ARM not working?
    Posted Mar 12, 2024 10:55 AM
    Are you using AirMatch?
    From the MM you can use the "show airmatch solution ap-name" - as well as other optimization commands - to get additional details.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 4.  RE: ARM not working?
    Posted Mar 13, 2024 04:27 AM
    If I issue this command on MM, see nothing.
    (mm1) [mynode] #show airmatch solution list-all
    # Band Radio              Chan/Opt#     CBW      EIRP(dBm)/Opt# Client Band  APName
        Pref  Pref
    [*] regarded frozen | [#] result adjusted to match feasibility
    Client Preference    - [p] HE Preferred | [n] Non-HE Preferred | [a] Allow-All
    Band Preference      - [L] 5GHz-Lower | [U] 5GHz-Upper | [F] 5GHz-Full
    (mm1) [mynode] #
    (mm1) [mynode] #show ap database-summary
    AP Database Summary
    AP Mode              Total Up  Total Down  Total Upgrading*  Total Rebooting*  RAP Up  RAP Down  RAP Upgrading*  RAP Rebooting*  Active Up  Standby Up
    Access Points        600       0           0                 0                 0       0         0               0               0          0
    Air Monitors         0         0           0                 0                 0       0         0               0               0          0
    Wired Access Points  0         0           0                 0                 0       0         0               0               0          0
    Mesh Portals         0         0           0                 0                 0       0         0               0               0          0
    Mesh Points          0         0           0                 0                 0       0         0               0               0          0
    Spectrum Monitors    0         0           0                 0                 0       0         0               0               0          0
    *Upgrading, Rebooting, Active and Standby counts only reflect APs registered on this controller.
    Unprovisioned Access Points:1
    Duplicated AP Name:0
    (mm1) [mynode] #
    However something working about Airmatch, I see radar detection events:
    (mm1) [mynode] #show airmatch event all-events all-aps
    Band Event Type   Radio             Timestamp           Chan    CBW      New Chan    New CBW   APName
    5GHz RADAR_DETECT bc:9f:e4:aa:aa:aa 2024-03-13_09:06:14     116    40MHz          52     40MHz
    5GHz RADAR_DETECT b8:3a:5a:bb:bb:bb 2024-03-13_08:05:33     120    40MHz          60     40MHz
    5GHz RADAR_DETECT bc:9f:e4:cc:cc:cc 2024-03-13_08:01:56      60    40MHz         108     40MHz
    5GHz RADAR_DETECT bc:9f:e4:dd:dd:dd 2024-03-13_07:30:39     128    40MHz         132     40MHz
    5GHz RADAR_DETECT bc:9f:e4:ee:ee:ee 2024-03-12_17:34:26     100    40MHz         116     40MHz
    5GHz RADAR_DETECT b8:3a:5a:ff:ff:ff 2024-03-12_14:50:20     116    40MHz         112     40MHz
    5GHz RADAR_DETECT bc:9f:e4:aa:aa:aa 2024-03-12_14:38:57     108    40MHz         124     40MHz
    5GHz RADAR_DETECT bc:9f:e4:bb:bb:bb 2024-03-12_14:33:04     116    40MHz         124     40MHz
    5GHz RADAR_DETECT bc:9f:e4:cc:cc:cc 2024-03-12_14:28:08     132    40MHz         128     40MHz
    5GHz RADAR_DETECT bc:9f:e4:dd:dd:dd 2024-03-12_13:05:18     124    40MHz         120     40MHz
    5GHz RADAR_DETECT b8:3a:5a:ee:ee:ee 2024-03-12_12:54:44      60    40MHz         100     40MHz
    5GHz RADAR_DETECT bc:9f:e4:ff:ff:ff 2024-03-12_10:57:00     136    40MHz          64     40MHz
    5GHz RADAR_DETECT bc:9f:e4:aa:aa:aa 2024-03-12_10:56:53      56    40MHz          64     40MHz
    5GHz RADAR_DETECT bc:9f:e4:bb:bb:bb 2024-03-12_10:33:19     124    40MHz         108     40MHz
    5GHz RADAR_DETECT bc:9f:e4:cc:cc:cc 2024-03-12_09:27:23     132    40MHz         116     40MHz
    5GHz RADAR_DETECT bc:9f:e4:dd:dd:dd 2024-03-12_09:23:51      52    40MHz         116     40MHz
    5GHz RADAR_DETECT b8:3a:5a:ee:ee:ee 2024-03-12_09:00:19     124    40MHz         132     40MHz
    5GHz RADAR_DETECT bc:9f:e4:ff:ff:ff 2024-03-11_14:32:16     116    40MHz         124     40MHz
    5GHz RADAR_DETECT bc:9f:e4:aa:aa:aa 2024-03-11_14:23:27      64    40MHz          56     40MHz
    --More-- (q) quit (u) pageup (/) search (n) repeat
  • 5.  RE: ARM not working?
    Posted Mar 13, 2024 10:36 AM
    What is the output of:
    #show airmatch debug optimization
    #show airmatch profile
    Zak Chalupka
    wifizak@hpe.com
  • 6.  RE: ARM not working?
    Posted Mar 13, 2024 10:41 AM
    (mm1) [mynode] #show airmatch debug optimization
        Channel  Opmode
    Seq   Time                   APs   [5GHz] Radios Cost  Conflict      [2GHz] Radios Cost  Conflict      [6GHz] Radios Cost  Conflict    Type                 Computed Computed
    #606    2024-03-02_05:00:12       2              2     2        0                  2     4        0                  0    NA       NA               Scheduled      Yes       No
    * EIRP is always computed in optimization
    (mm1) [mynode] #show airmatch profile
    AirMatch profile
    Parameter          Value
    schedule           Enabled
    deploy-hour        5 AM
    quality-threshold  8 percent
    (mm1) [mynode] #
  • 7.  RE: ARM not working?
    Posted Mar 13, 2024 10:46 AM
    Reboot the MCR.
    Run "airmatch runnow full".
    A solution should be generated after a time.
    If that doesn't work, open a case with TAC as you've got some sort of issue going on.
