Wired Intelligent Edge
ARP and DHCP Inspection on UBT Mode
This thread has been viewed 21 times
  • 1.  ARP and DHCP Inspection on UBT Mode
    Posted Jan 17, 2022 06:29 AM
    Trying to implement DHCP and ARP snooping on AOS switches with UBT mode on. Will enabling these features on Tunnel-Reserved-Vlan on access switches be enough for all UBT vlans that reside on the core side?
    Pavan.
    Pavan Kumar Potru
  • 2.  RE: ARP and DHCP Inspection on UBT Mode
    Posted Jan 18, 2022 05:27 AM
    I would think you should enable those features on the controller/gateway, as with UBT all traffic is handled there.
  • 3.  RE: ARP and DHCP Inspection on UBT Mode
    Posted Jan 18, 2022 06:05 AM
    Thanks Herman.
    If we have to apply on both switch (Customer's security requirement) and controller,
    On switch - trusting uplink port and Tunnel-Reserved-Vlan be enough ?
    On Controller - Will configure as normal. Uplink trunk and uplink vlans as trust.
    Pavan Potru
  • 4.  RE: ARP and DHCP Inspection on UBT Mode
    Posted Jan 21, 2022 02:53 AM
    I would not know... probably the best is to check with TAC, or just test it. Not sure if it is supported.
  • 5.  RE: ARP and DHCP Inspection on UBT Mode
    Posted Jan 21, 2022 04:46 AM
    Thanks Herman. Logged a call with TAC.
    Pavan Kumar Potru
  • 6.  RE: ARP and DHCP Inspection on UBT Mode
    Posted Jan 28, 2022 07:27 AM
    Is it working in UBT Mode ?
