Arruba 515's no HTTP
  • 1.  Arruba 515's no HTTP
    Posted Apr 16, 2019 12:41 PM
    We recently deployed new 515's in our enviorment, and we cant get to any website. We are able to ping and the traceroute shows the correct path. We changed the access rules to allow any to all destinations, with no luck.
    We noticed we are able to do reverse DNS lookup but not Forward DNS look up. Any suggestions are appreciated
    Thank you
  • 2.  RE: Arruba 515's no HTTP
    Posted Apr 17, 2019 05:31 AM
    This question cannot be answered with just AP type. Firmware version, deployment type (Instant/controller/tunneled/remote/bridged), authentication type, role configuration, Application filtering all can be relevant. What you describe, only reverse DNS, doesn't ring a bell makes sense for a straight-forward configuration. What you can do is a 'blind' firmware upgrade to the latest version and see if that helps, or disable all features that you don't need and go back to the bare minimum to see if that works.
    Please reach out to your Aruba partner or Aruba TAC support as they may ask the right questions to find out what may be configured wrong.
