Aruba 105 clients not receiving dhcp address
  • 1.  Aruba 105 clients not receiving dhcp address
    Posted Oct 17, 2013 10:31 PM
    I'm trying to get an Aruba 105 AP to broadcast two SSID. One public SSID and one private SSID.    The issue that I'm trying to work through is it appears as if wireless clients are unable to receive a DHCP address.
    I have both WLANS configured as follows:
          Employee or Guest
          Client IP Assigned:  Network
          Client VLAN assignement:  Static, 20
          Allow DHCP to all destinations
          Allow all traffic to all destinations
    I've updated the fireware to the current release:  6.2.1.0-3.4.0.1_39461
    VLAN 20 is configured with an IP Helper address to the DHCP server
    Switch type is Cisco Catalyst 3750
    DHCP server is on VLAN 10 but has a DHCP scope for VLAN 20
    Switch port is configured as access.   Would like to configure as a trunk port but had other difficulty.
    Thanks in advance for any help.
  • 2.  RE: Aruba 105 clients not receiving dhcp address
    Posted Oct 17, 2013 10:57 PM
    You need to configure the port as trunk so you can trunk several VLANs : Management VLAN to reach the Virtual Controller and  VLAN 20
    Make sure to make the wired profile with Management VLAN as the Native VLAN
