Aruba 105-IAP DHCP
  • 1.  Aruba 105-IAP DHCP
    Posted Feb 27, 2014 03:45 PM
    I have an Aruba IAP-105, the scenario is my Aruba 105 is connect via PoE set to vlan 30 the IP subnet for  Vlan 30 is 192.168.0.x for management only and i want my wireless client to get the IP subnet 192.168.1.x that belong to Vlan 10.
    What configuration I need to do in my IAP? I have a Windows DHCP server.
  • 2.  RE: Aruba 105-IAP DHCP
    Posted Feb 27, 2014 04:30 PM
    Create a wired port profile :
    Make it a trunk
    Create local centralize scope using the ip address of your DHCP server as the IP helper address (relay)
    And then add the VLAN 10 to the network settings
  • 3.  RE: Aruba 105-IAP DHCP
    Posted Feb 27, 2014 04:37 PM
    Thanks for the fast reply Sir Victor.
    I will try this config later.
    By the way do i need to set my port in switch to trunk mode? currently it is in access mode.
    TIA
  • 4.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 02:54 PM
    Hi Victor,
    I followed your advice but my laptop can't get IP from my DHCP.
    Can you help me what's missing on the config. TIA
  • 5.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 03:10 PM
    Ralph,
    You're going to need to configure your switchport leading to the IAP to match with same trunking parameters.
    no switchport mode access
    switchport mode encapsulation dot1q
    switchport mode trunk
    switchport trunk native vlan 30
    switchport trunk allowed vlan 10,30
  • 6.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 03:13 PM
    Good point net
    Thank you
    Victor Fabian
    Carousel Industries
  • 7.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 03:25 PM
    @Hi victor. I added the vlan 10 to SSID
    @Networker
    I will try it thanks
  • 8.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 03:28 PM
    After you enter those commands you should be able to do a "show interface trunk" on the switch (if Cisco) and see the port trunking w/ IAP using Native VLAN 30.
    If you issue that command and don't see your switchport interface which leads to the IAP on there......then it's not trunking. At that point try a "shut" and "no shut" on the interface.
  • 9.  RE: Aruba 105-IAP DHCP
    Posted Mar 02, 2014 10:59 AM
    Hi guys, thanks for the help.
    I was able to complete my project with your help!
  • 10.  RE: Aruba 105-IAP DHCP
    Posted Feb 28, 2014 03:04 PM
    Did you assigned the static VLAN under the ssid settings ?
