Wired Intelligent Edge
  • 1.  Aruba 10G SFP+ Transceivers MSA Compliant
    Posted May 04, 2020 06:30 AM
    Hi, the Aruba 10G SFP+ Transceivers J9150D and J9151E, are the SFP+ transceiver MSA compliant?
    Thank you!
  • 2.  RE: Aruba 10G SFP+ Transceivers MSA Compliant
    Posted May 04, 2020 05:14 PM
    Hi! Actually EoS Aruba Networks MAS (Mobility Access Switch) series, as it is known, used - and still supports - these Aruba Networks SKUs [*]:
    • JW087A SFP-LX 1000BASE-LX SFP 1310nm LC Connector Pluggable GbE Transceiver
    • JW088A SFP-SX 1000BASE-SX SFP 850nm LC Connector Pluggable GbE Transceiver
    • JW089A SFP-TX 1000BASE-T SFP Copper GbE RJ45 Connector Pluggable Transceiver
    • JW090A SFP-10GE-LRM 10GBASE-LRM SFP+ 1310nm LC Connector Pluggable 10GbE Transceiver
    • JW091A SFP-10GE-SR 10GBASE-SR SFP+ 850nm Pluggable LC Connector 10GbE Transceiver
    • JW092A SFP-10GE-LR 10GBASE-LR SFP+ 1310nm Pluggable LC Connector 10GbE Transceiver
    • JW101A DAC-SFP-10GE-1M 1m 10GbE SFP+ Twinax Connectors Direct Attach Cable
    • JW102A DAC-SFP-10GE-3M 3m 10GbE SFP+ Twinax Connectors Direct Attach Cable
    • JW100A DAC-SFP-10GE-50CM 50cm10GbE SFP+ Twinax Connectors Direct Attach Cable
    • JW103A DAC-SFP-10GE-5M 5m 10GbE SFP+ Twinax Connectors Direct Attach Cable
    • JW104A DAC-SFP-10GE-7M 7m 10GbE SFP+ Twinax Connectors Direct Attach Cable
    [*] The above legacy Aruba Networks SKUs supported on MAS series are not the same actually supported on current switch series driven by ArubaOS-Switch or ArubaOS-CX NOS.
    The above doesn't necessarily mean that HPE Aruba SKUs can't work (here "work" doesn't mean "supported") on legacy Aruba Networks MAS. The contrary very unlikely.
  • 3.  RE: Aruba 10G SFP+ Transceivers MSA Compliant
    Posted May 04, 2020 10:34 PM
    Hi, what i meant is actually industry's MSA (Multi-Source Agreement) standards for optical transceiver: https://en.wikipedia.org/wiki/Multi-source_agreement
  • 4.  RE: Aruba 10G SFP+ Transceivers MSA Compliant
    Posted May 04, 2020 10:53 PM
    Oh, my bad...confused MSA with MAS. Forget better. This is really a question for HPE Aruba (Transceivers) PM.
