Aruba 135 SNMP walk
  • 1.  Aruba 135 SNMP walk
    Posted Oct 10, 2014 04:42 PM
    I am using Solarwinds to monitor my Aruba 135 controller.  Doing an SNMP walk results in this:
    .1.3.6.1.2.1.1.1.0 = STRING: "ArubaOS Version 6.2.1.0-3.3.0.3"
    .1.3.6.1.2.1.1.2.0 = OID: 1.3.6.1.4.1.14823.1.2.48
    .1.3.6.1.2.1.1.3.0 = TIMETICKS: 1925998
    .1.3.6.1.2.1.1.4.0 = STRING: ""
    .1.3.6.1.2.1.1.5.0 = STRING: "9c:1c:12:c5:65:60"
    Bur Solarwinds says it is looking for this:
    RolewlsxSwitchRole1.3.6.1.4.1.14823.2.2.1.1.1.4
    HostNamewlsxSysExtHostname1.3.6.1.4.1.14823.2.2.1.2.1.2
    ModelNamewlsxSysExtModelName1.3.6.1.4.1.14823.2.2.1.2.1.3
    What can I do to monitor my device?
  • 2.  RE: Aruba 135 SNMP walk
    Posted Oct 10, 2014 04:45 PM
     I am monitoring the static IP of the device and am at ArubaOS Version 6.2.1.0-3.3.0.3.
  • 3.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 09:40 AM
    Please upgrade to 4.1+ as SNMP has been fixed in this version.
    This post covers snmpwalking
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/SNMPWALKing-the-VC-does-not-always-respond/m-p/91112/highlight/true#M2512
  • 4.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:07 AM
    How do I upgrade to 4.1?  My Aruba says I can go from 6.2.1.0-3.3.0.3_39227 to 6.3.1.8-4.0.0.7_44641.   Is this it?
  • 5.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:12 AM
    If you have a support account you can download the firmware from support.arubanetworks.com.
    If not, 4.1 has not made it to the cloud as of yet.
    I suggest upgrading to 4.0.0.7 and it may give you the option of 4.1, your firmware just may be too old.
    Let me see if my IAP with an older firmware gives me the option to upgrade to 4.1
  • 6.  RE: Aruba 135 SNMP walk
    There are two ways you can do upgrades -- the first is using the cloud upgrade servers like you showed and the second is to log into the TAC website and manually download SW (requires an account).
    The cloud typically lags several months behind the releases posted to TAC.
  • 7.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:25 AM
    So after upgrading my IAP to 4.0.0.7, there is no new version available.
    What is interesting though is that IAPs on 4.1.0.0 see a new version in the cloud which is 4.1.1.0.
    So if you're not already on 4.1, you need to download from the support site, if you are on 4.1, then you can download the latest from the cloud
  • 8.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:26 AM
    Thanks!   I do have a support account, but where is it located?
  • 9.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:28 AM
  • 10.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:33 AM
    Aha!   Thank you.  One last stupid question, and I appreciate everyone's patience, where are the instructions for doing the upgrade?  I looked in teh release notes PDF and did not find them.
  • 11.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 11:24 AM
    FOUND IT!   Tftp to the rescue.   Thanks everyone!
  • 12.  RE: Aruba 135 SNMP walk
    Posted Oct 15, 2014 10:30 AM
    Log into support.
    Navigate to Download Software -> Aruba Instant -> Current Releases -> Release 6.4.2.0-4.1 ->
    Download the following firmware
    [Details]
    ArubaInstant_Cassiopeia_6.4.2.0-4.1.1.0_46028
    Here is a link to it
    support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=15125
