Wired
Aruba 1960 InstantOn - Can't route IP packets between VLANs
  • 1.  Aruba 1960 InstantOn - Can't route IP packets between VLANs
    Posted Dec 15, 2022 11:30 AM
    Can  anyone help me.
    I am trying to use the Layer 3 IP routing in the 1960 switch series to route IP packets between subnets on different VLANs.
    I configure a switch with two VLANs, enable routing and define static IP addresses for each VLAN interface in the switch.
    A computer on each VLAN can ping the switch at the IP address of the VLAN interface for that computer, and I can PING the interface on the switch on the other VLAN.
    However, I can route packets through the switch to another computer on the other VLAN.
    Computer 1 - VLAN 1 (192.168.1.2)
    Switch JL806A   VLAN 1 (192.168.1.1) and VLAN 2 (192.168.2.1)
    Computer 2 - VLAN 2 (192.168.2.2)
    Computer 1 and 2 can each ping both interfaces on the switch.
    Computer 1 & 2 can't ping each other
    The manual indicates that the switch does route packets at Layer 3.
    Help!
  • 2.  RE: Aruba 1960 InstantOn - Can't route IP packets between VLANs
    Posted Dec 15, 2022 12:03 PM
    Please ask your question on the Aruba InstantON forum
