Aruba 205 Virtual Controller Guest Network Splash Page...
  • 1.  Aruba 205 Virtual Controller Guest Network Splash Page...
    Posted Dec 18, 2015 04:55 PM
    Aruba 205  Virtual Controller Guest Network Splash Page...There is not enough room for me to type in my AUP or T & C policy when using internal auth it only allows up to 255 Char.
    How can i incorporate my own splash page or modify the internal one ?
    Thank You
    #AP205
  • 2.  RE: Aruba 205 Virtual Controller Guest Network Splash Page...
    Posted Dec 18, 2015 05:04 PM
