Aruba 205H - add access point
  • 1.  Aruba 205H - add access point
    Posted Dec 25, 2019 09:48 AM
    I just wander if someboud could help me. I have 4xAruba 205H in network and need to buy new one and add to virtual controller. Could you advise which model avaliable recently will work please?
    Thank you
  • 2.  RE: Aruba 205H - add access point
    MVP
    Posted Dec 25, 2019 10:16 AM
  • 3.  RE: Aruba 205H - add access point
    Posted Dec 25, 2019 10:19 AM
    And they both work with IAP 205H. Will 207 work as well?
  • 4.  RE: Aruba 205H - add access point
    Posted Dec 25, 2019 11:11 AM
    Let's start with what version of Aruba Instant you are running right now.  That will determine if the 205H and the other access points can coexist.
  • 5.  RE: Aruba 205H - add access point
    Posted Jan 02, 2020 04:04 AM
    Thank you cjoseph
  • 6.  RE: Aruba 205H - add access point
    MVP
    Posted Dec 25, 2019 01:42 PM
    IAP 205H minimum Instant OS is 4.2.0.0
    IAP-207 minimum InstantOS is 4.3.1.0.
    IAP-303H minimum InstantOS is 6.5.2.0/8.2.0.0
    IAP-203H minimum InstantOS is 6.5.3.0/8.2.0.0
    So it means that you have to upgrade the existing iAPs to 4.3.1.0 and it shouldn't be a problem to support IAP-207.
    On the regards of IAP-303H & IAP-203H, if you want to move to those IAPs, then you have to upgrade the existing IAP to 6.5.2.0 or 6.5.3.0.
    The IAP-205H supports 6.5.3.0, check the image attached.
    Refer to the Datasheets bellow as well for the InstantOS supported by IAPs:
    IAP-207 https://www.arubanetworks.com/assets/ds/DS_AP207Series.pdf
    IAP-205H https://www.arubanetworks.com/assets/ds/DS_AP205H.pdf
    IAP-303H https://www.arubanetworks.com/assets/ds/DS_AP303H.pdf
    IAP-203H https://www.arubanetworks.com/assets/ds/DS_AP203H.pdf
  • 7.  RE: Aruba 205H - add access point
    Posted Jan 02, 2020 04:01 AM
    Thank you Shpat
