Aruba 205H UI access after "Instant" SSID disappears
  • 1.  Aruba 205H UI access after "Instant" SSID disappears
    Posted Sep 30, 2015 07:13 PM
    Hi, how do I get to 205H UI to change options of the new SSID I've created moment ago? Thanks.
  • 2.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Sep 30, 2015 09:18 PM
    You need to web into the same GUI....
  • 3.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Oct 01, 2015 02:01 AM
    Hi Colin,
    But how do I get to GUI, please? Typing http://instant.arubanetworks.com doesn’t work. During SSID set-up I have furthermore added captive portal. So when I switch on Wi-Fi on my laptop and connect to my new SSID, default captive portal appears (see attached print screen). BUT when I click on "Accept” button, web page redirects to https://securelogin.arubanetworks.com/swarm.cgi which is a blank page. That’s why I need to get to UI and cancel that captive portal option.
    I also cannot reset AP to factory settings because I don’t have a console cable and couldn’t find any other option.
    Thank you for your help.
    Jaroslav
  • 4.  RE: Aruba 205H UI access after "Instant" SSID disappears
  • 5.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Oct 01, 2015 04:01 AM
    If you mean button circuled in red in attached picture, that doesnt work unfortunatelly. There is no web address like 192.168.1.1 thru which I can access UI? It already took me 3 hours to figure out how to access UI :(
    Thank you.
    Jaroslav
  • 6.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Oct 01, 2015 04:06 AM
    The instant device comes with instructions o how to access the webui.  Also, the reset button should work with the instructions at the link I sent.
  • 7.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Oct 01, 2015 04:24 AM
    The hardware installation Guide for the 205H is here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17574
    The instant quickstart guide is here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=18362
    Instant user guide:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=18858
    Lastly, the Knowledgebase, just in case you have to find things:  http://community.arubanetworks.com/t5/Support/ct-p/Support-Documentation-Downloads
    The reset button should work with the instructions I gave you.  If you have access to the GUI please note the ip address of the instant Virtual Controller.  Users who just login to the captive portal are not supposed to know what the ip address is, that is why it does not appear anywhere...
  • 8.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Oct 01, 2015 11:32 AM
    Also are you accessing the UI through the default "instant" SSID that should be broadcasting in factory default?
    Sent from my iPhone
  • 9.  RE: Aruba 205H UI access after "Instant" SSID disappears
    Posted Jun 16, 2017 12:17 PM
    You can access the GUI by entering the VC IP or master AP IP in a web browser.
    Julián
