Aruba 207 Green-Flashing (stuck on green flashing).
  • 1.  Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 08:44 AM
    Hi Everyone
    I have an API207,it is connected to DC Supply.
    The power light continually flash green on API207.
    Reply from 192.168.1.210: bytes=32 time<1ms TTL=64
    I do not have a console cable.
    When I installed it i simply plugged it into my switch then I accessed it via the browser at https://instant.arubanetworks.com:4343/#home
    Now I cannot access the device.
    What causes. ?
    Any help would be greatly appreciated
  • 2.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 11:09 AM
    @geraldst wrote:
    Hi Everyone
    What causes. ?
    How did you determine that the AP is using the IP address 192.168.1.210? Can you ssh to the IP address, or use https://192.168.1.210:4343?
    Without console access, troubleshooting will be limited. Do you have local access to the 192.168.1.0 wired subnet?
  • 3.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 02:16 PM
    Hi Charlie,
    Thanks for you answer.
    From DHCP server, I saw the mac address, then I checked the cable in/out.
    I bought the first time in July 2xAP207 (Model:APIN0207 JX952A AP-207) and when I wanted to configure them, I received the same problem "green led flashing on both AP". Back then I opened the RMA and the two devices were replaced. With the new devices I have the same "error".
    To solve the problem, I tried:
    - DC Supply no result
    - PoE Switch no success.
    - replace cable
    - another place (switch locations)
    In the past, I have already worked with identical AP devices, we have in the HQ 3xAP-207 and in the secondary office 7xAP-207  without controller. With these previous devices I didn't have any Problem.
    Only with these two new ones I have encountered this error.
    Could it be that the new devices themselves have a problem, all four of them?...hard to believe....
    (view in My Videos)
    Something goes wrong but I can't tell what.
    Thank you
  • 4.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 03:12 PM
    Reply from 192.168.178.41: bytes=32 time=1ms TTL=64
    Request timed out.
    Request timed out.
    Reply from 192.168.178.20: Destination host unreachable.
    Reply from 192.168.178.41: bytes=32 time=3ms TTL=64
    - no wifi signal
    - no web access
    - no SSID (instant-aruba)
    - no ssh/telnet
    C:\Users\user>arp -a 192.168.178.41
    Interface: 192.168.178.20 --- 0x1b
    Internet Address Physical Address Type
    192.168.178.41 80-8d-b7-c2-11-b4 dynamic
  • 5.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 03:14 PM
    Does the sticker on that access point say IAP-207 or AP-207?  AP-207 would work the way you are describing.  The IAP-207 would broadcast the instant SSID and you would be able to SSH into it.
  • 6.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 05:05 PM
    Thanks for your answer
    AP-207
  • 7.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 13, 2018 05:36 PM
    AP-207
    The AP-207 does not work without a controller. The models you used previously without a controller would have been IAP-207s. The correct SKU would depend on the country code that needs to be supported.
  • 8.  RE: Aruba 207 Green-Flashing (stuck on green flashing).
    Posted Aug 14, 2018 04:02 AM
    I bought the wrong item on HP reseller.
    This is correct IAP-207-RW.
    Thank you Charlie
