Wired Intelligent Edge
Aruba 2530-24G
  • 1.  Aruba 2530-24G
    Posted Nov 05, 2020 11:18 AM
    Within the Web GUI Interface if I expand Interfaces a select Ports I see no Statistics.  Is this a Firmware issue or a setting I have missed?  I have an Aruba 2530-48G switch that I have no issues with.  When I go to the same area on it's Web GUI I see all the Ports and their information.
    See attached screen shots
    Any help would be greatly appreciated
    Tim Brzezowski
  • 2.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:20 AM
    What version of code is it running?
    Justin Noonan
  • 3.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:27 AM
    Primary Software: YA.16.06.0006 (Booted)
    Secondary Software: YA.16.06.0012
    ROM: YA.15.20
    Tim Brzezowski
  • 4.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:29 AM
    That's a pretty old version, any chance you could upgrade that?  It may have been an old bug.
    Justin Noonan
  • 5.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:31 AM
    You mean boot to the Secondary or is there an even newer firmware than .0012?
    Tim Brzezowski
  • 6.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:36 AM
    We are now on 16.10.  Is there any reason you need to stay on 16.06?
    Aruba Support Portal - link to 16.10
    Document Display | HPE Support Center - release notes
    Justin Noonan
  • 7.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 11:42 AM
    No reason.  I can update to the latest.  Thanks for this information.  Is this a direct upgrade or is there a stepping path I need to take?
    Tim Brzezowski
  • 8.  RE: Aruba 2530-24G
    Posted Nov 05, 2020 12:46 PM
    You can directly upgrade, it may do an extra reboot for a bootrom update.  I think there was an update at some point between 16.06 and 16.10.
    Justin Noonan
