Wired Intelligent Edge
Aruba 2530-48G-PoE+ - PoE issues?
  • 1.  Aruba 2530-48G-PoE+ - PoE issues?
    Posted Nov 28, 2019 11:48 AM
    Hi all,
    I'm experience a strange behavior with Aruba 2530-48G PoE+ (J9772A), after a power outage some APs didn't get power from PoE.
    I have checked the PoE Port status and it was in "Searching".
    A couple of hours later the PoE Port status was "Delivering" and the AP is back online without any intervention.
    All the cabling was checked a retested and we didn't find any issue. Did some one experienced any situation similar like this?
  • 2.  RE: Aruba 2530-48G-PoE+ - PoE issues?
    Posted Nov 30, 2019 09:07 PM
    What type of devices are connected to the 2530-48G-PoE+ Switch ?
    The following are the different "Detection Status":
    Searching: The port is trying to detect a PD connection.
    Delivering: The port is delivering power to a PD.
    Disabled: On the indicated port, either PoE support is disabled or PoE power is enabled but the PoE module does not have enough power available to supply the port's power needs.
    Fault: The switch detects a problem with the connected PD.
    Other Fault: The switch has detected an internal fault that prevents it from supplying power on that port.
    Try to check the logs.
    show logging -r -w
    Better to log a TAC Case if you are able to reproduce the issue (or) find anything useful in the logs.
  • 3.  RE: Aruba 2530-48G-PoE+ - PoE issues?
    Posted Dec 06, 2019 06:12 AM
    Hi Kapildev
    Regarding your question we have Ruckus AP H510 connected to the switch. On top of the Ruckus AP we have a IPTV STB
    I have checked the logs but didn't find anything suspicius or strange.
    Let's see if we are able to reproduce this issue.
