Aruba 2530 not enough PoE
  • 1.  Aruba 2530 not enough PoE
    Posted Aug 08, 2018 07:51 AM
    Hey! First time posting here and didn't quite know where to open my topic.
    Anyways here is my problem
    I set up a few AP305 in a school.
    My Aruba 2530 8G PoE has a PoE capacity of 67W.
    Aruba AP305 power consumption is 13W worst case scenario.
    If my math adds up it should supply 5 AP305 in worst case scenario and yet it supplies only 3 or maybe 4 if I am lucky.
    Am I missing something? It's messing with my planning and making it kinda akward to explain my customer that he needs to upgrade to a bigger switch.
    All these informations have been taken from arubanetworks.com
    Thanks in advance!
    Sincerely Kevin
  • 2.  RE: Aruba 2530 not enough PoE
    Posted Aug 08, 2018 10:27 AM
    What is the POE budget that the 2530 is reserving for each AP305? I suspect that the 2530 is reserving 15.4W of POE per port (class 3), of which each AP305 will pull a max of 13W (assuming no USB powered devices are used on the 305s). If the switch is reserving a full 15.4W, then the math works out that 4 APs would be supported, assuming no other POE devices on the switch.
  • 3.  RE: Aruba 2530 not enough PoE
    Posted Aug 09, 2018 02:34 AM
    I didn't know it would reserve up up too 15.4W of POE per port.
    Is it possible to turn it down so it can support one more unit?
    But it makes sense that way! Thanks!
  • 4.  RE: Aruba 2530 not enough PoE
    Posted Aug 09, 2018 10:05 AM
    It has to do with how POE needs are signalled (via the standards: 802.3af, 802.3at, and the power class of the device) ... and that the length of cable will attenuate the actual power delivered to the device over distance.
  • 5.  RE: Aruba 2530 not enough PoE
    Posted Nov 13, 2019 10:11 AM
    I've the same issue with my 2530 switchs {HP 2530-48-PoEP Switch (J9778A)}, when I connect a Cisco LWAP 702i they don't work correctly, they register successfully agains the WLC, but de operational radio are down. If I connect the same APs to a Cisco 2960 or 3Com 4500 switch, they work fine.
    I changed all parameters about CPD, LLP, PoE.... but without success, and I used a new 1 meter long RJ45 CAT6, but nothing improved.
    switch# show system
    Software revision : YA.16.10.0002 Base MAC Addr : 98f2b3-438680
    ROM Version : YA.15.20 Serial Number : CN77FP32RD
    switch# show power-over-ethernet 43
    Status and Configuration Information for port 43
    Power Enable : Yes PoE Port Status : Delivering
    PLC Class/Type : 3/1 Priority Config : critical
    DLC Class/Type : 0/- Pre-std Detect : on
    Alloc By Config : usage Configured Type :
    Alloc By Actual : usage PoE Value Config : n/a
    PoE Counter Information
    Over Current Cnt : 0 MPS Absent Cnt : 0
    Power Denied Cnt : 0 Short Cnt : 0
    switch# show lldp config 43
    LLDP Port Configuration Detail
    Port : 43
    AdminStatus [Tx_Rx] : Tx_Rx
    NotificationEnabled [False] : True
    Med Topology Trap Enabled [False] : False
    TLVS Advertised:
    * port_descr
    * system_name
    * system_descr
    * system_cap
    * management_addr
    * capabilities
    * network_policy
    * location_id
    * poe
    * macphy_config
    * poeplus_config
    * eee_config
    * Port VLAN ID
    IpAddress Advertised:
    switch# show lldp info remote-device 43
    LLDP Information
    PSE Allocated Power Value : 2.7 W PSE TLV Configured : dot3, MED
    PD Requested Power Value : 0.0 W PSE TLV Sent Type : dot3
    MED LLDP Detect : Disabled PD TLV Sent Type : n/a
    Power Information
    PSE Voltage : 55.4 V PSE Reserved Power : 2.9 W
    PD Amperage Draw : 50 mA PD Power Draw : 2.8 W
    LLDP Remote Device Information Detail
    Local Port : 43
    ChassisType : local
    ChassisId : AP_C01ST1_5
    PortType : local
    PortId : GigabitEthernet0.1
    SysName : cisco AIR-CAP702I-E
    System Descr : Cisco IOS Software, ap1g1 Software (ap1g1-K9W8-M), Versio...
    PortDescr :
    Pvid :
    System Capabilities Supported : router
    System Capabilities Enabled : router
    Remote Management Address
    Type : ipv4
    Address : 10.50.216.45
    Local Port : 43
    ChassisType : mac-address
    ChassisId : 50 06 04 2e f3 60
    PortType : interface-name
    PortId : Gi0
    SysName : AP_C01ST1_5
    PortDescr : GigabitEthernet0
    Pvid :
    Type : ipv4
    Any idea to help me ??
    Thanks !!
