Aruba 2530 port-access auth-mode
This thread has been viewed 16 times
  • 1.  Aruba 2530 port-access auth-mode
    Posted 14 days ago
    Hi Guys,
    I'm looking for a command like aaa authentication port-access auth-mode (AOS-CX), to configure in Aruba 2530.
    the purpose is to authenticate a single MAC (of an Access Point), without authenticating mac address coming for them.
    Thanks.
  • 2.  RE: Aruba 2530 port-access auth-mode
    Posted 13 days ago
    This is the config snippet that I used before, it is using device attributes for local user roles
    aaa authorization user-role name "InstantAP-1x"
       policy "InstantAP"
       vlan-id 10
       vlan-id-tagged 20
       device
          port-mode
       exit
    exit
  • 3.  RE: Aruba 2530 port-access auth-mode
    Posted 13 days ago
    Thanks for the answer.
    But my problem with user roles on this type of switch, is when I ran the command: aaa authorization user-role enable, so the switch will be able to use user roles.
    All ports got into Deny status, although I wanted to use the user role on 3 ports only.
    Any idea why it happened?
  • 4.  RE: Aruba 2530 port-access auth-mode
    Posted 13 days ago
    Hello @ariyap This is not valid for 2530 . It is valid from 2540 and upper .
    The only possible way to implement port-mode is via returning attributes from Clearpass The bellow is for MAC-AUTH
    This one is for dot1x
  • 5.  RE: Aruba 2530 port-access auth-mode
    Posted 12 days ago
    thanks for pointing it out, my snippet was for 2930F
  • 6.  RE: Aruba 2530 port-access auth-mode
    Posted 12 days ago
    Hi
    I have not worked with the 2530 switches and activated this. In the 2930F series the command is 'device port-mode'.
    According to the document Aruba 2530 Access Security Guide for AOS-S 16.09 RADIUS VSA assignments for ArubaOS-Switch are made under HPE Vendor-Specific ID 11 and the attribute hp-port-macauth-port-mode is controlling this setting.
    From the document:
    hp-port-macauth-port-mode Type #: 14
    Platforms supported: All
    Description:
    Sets the port to port-based mode for a MAC Authentication
    Length: 4 Type: Integer
    Value range: A port-based VSA is set with a value of 1.
    Format: HP-Port-Auth-Mode-MacAuth = 1
    Hopefully this can guide you in the right way.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
