Network Management
Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
This thread has been viewed 121 times
  • 1.  Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Feb 19, 2024 04:13 AM
    Hello everyone,
    Last week I updated my IMC to the latest version E0710P03 and then wanted to update the firmware of my Arubas 2530, 2930 and CX 6000 using a deployment task. This always worked before the IMC update, but now I get the following error on the 2530 and 2930:
    Is there anyone else getting this error? Is it a bug in the new IMC version?
    Thank you in advance and best regards
  • 2.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Feb 20, 2024 03:57 AM
    1. no consistency in version E0710P03 below E0708.P03
    2. 2540,2920,2930  <backup failed>
    but
    2626,2650,2824,5308,5400  <backup ok >- in my opinion it is a bug
    3. Problem with sorting by version of Avaible Software (Firefox,Chrome)
    Service > Configuration Center
     not working: sort by <Latest Available Version>
    Best Regards
  • 3.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Mar 05, 2024 03:44 PM
    Edited by knikolajczuk Mar 05, 2024 03:55 PM
    Hello
    same problem in my environment after upgrade to E0710P03.
    I cannot deploy task to device and cannot backup software. What is a strange for me that I can for example backup all config from stacked switches only. I think that this is bug and should be immediately fixed.
    Krzysztof
  • 4.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 03, 2024 06:08 AM
    Hello !
    Same problem here. Since last iMC update E0710P03 we are unable to flash 2530 series.
    Please HPE Team fix it immediatly.
    The alert CVE-2024-26303 is important and we must upgrade all switches as soon as possible !
    Best Regards.
    Michael
  • 5.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 03, 2024 06:13 AM
    If you have urgent issues, always open a case with Support. This community is for non-urgent issues, and not actively monitored/read by support or the product teams. Reaching out to support is the way to report such issues.
  • 6.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 15, 2024 12:32 PM
    config backup is partly wasted after updating to E0710P03. too.
    this is kinda annoying.
    some devices backup just fine (didn't actually check for details), some devices don't.
    2024-04-15 18:02:45.986 [INFO (2126)] [THREAD(10396)] [CComponentAdapter::getSupportAdapter()] ver info is ser:HPEAruba2930FSwitch vrp:N/A rel:N/A
    2024-04-15 18:02:45.986 [WARNING (2001)] [THREAD(10396)] [CComponentAdapter::getSupportAdapter()] Fail to get dev version,devID=118
    2024-04-15 18:02:45.986 [WARNING (43)] [THREAD(10396)] [CComponentAdapter::discoverDeviceAdapter()] fail to call getSupportAdapter(),devID=118
    2024-04-15 18:02:45.986 [DEBUG (0)] [THREAD(10396)] strAdapterName is N/A
    2024-04-15 18:02:45.986 [ERROR (43)] [THREAD(10396)] [CComponentAdapter::getDevAdapterName()] fail to call discoverDeviceAdapter()
    2024-04-15 18:02:45.986 [ERROR (43)] [THREAD(10396)] [CComponentAdapter::isDevSupportServiceAction()] fail to call getDevAdapterName().DevID=118,ServiceName = ConfigBackup
    a workaround would be nice.
  • 7.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 16, 2024 04:42 AM
    support have a patch for  this problem, you can request it with a support ticket.
    Problem  will be fixed in the next release.
    Kind regards
    Paola
    Kind Regards
    Paola
  • 8.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 17, 2024 02:19 AM
    Hi all,
    Thank you @pbit for the information of the patch.
    My iMC server is now fully operational. I can update the firmware of all my switches.
    Best Regards.
    Michael
  • 9.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 10, 2024 07:26 AM
    since TAC wasn't - sorry to say - of much help here, and E0710P04 didn't fix the problem of being unable to backup some (not all) devices, i fiddled around and could get iMC to backup all of our devices just like before.
    i'll share my findings - hopefully this helps someone out there. here's what i did
    • switched to plain text password view in system settings (no idea whether this was crucial)
    • accessed the device page of a switch that wouldn't do a config backup
    • Configure -> Modify SSH Settings
    • without changing anything, i pressed the 'Test' button, waited for the 'Success' message and pressed 'OK' afterwards
    did that for all the failed devices, et voilá... config backup works for all devices as expected.
  • 10.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 10, 2024 12:41 PM
    sorry you had so much trouble.  Could you please share the ticket number and I will check why you didn't get the hot patch for 710P03 which  cleared this problem.
    Unfortunately the developers forgot to put in the 710P04 readme the instruction to synchronize the devices after upgrade..
     I have written a knowledgebase and it will be published soon. Here is a screenshot.
    Kind Regards
    Paola
  • 11.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 11, 2024 02:59 AM
    hi Paola,
    thanks for getting back.
    case nr. was 5381394580.
    in fairness, i have to say that i agreed to wait for the next release and to close the ticket since the proposed workaround would have involved manually fiddling about with OIDs.
    best regards
  • 12.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 11, 2024 03:25 AM
    Hi Markus,
    from our testing,  the problems have been resolved in 710P04, but the release notes missed instructions to sync the devices.
    I have written a knowledgebase to recommend it and included your workround to test SSH configuration, thank you and sorry again.
    https://support.hpe.com/hpesc/public/docDisplay?docId=sf000102606en_us&noframe
    Paola
    Kind Regards
    Paola
  • 13.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 26, 2024 03:34 AM
    Hi all,
    I have been following this thread with interest as I have been having the same issues relating E710P03 with 2530/2930F series.
    After raising TAC ticket I have updated to E710P04 and after a synchronization backups are now working on a reliable basis.
    I am however struggling now to deploy firmware to 2530/2930 using SSH to communicate and TFTP for firmware delivery. The process starts correctly and actually copies the firmware to the target device (Viewed in IMC log and on switch event log), however after this it fails and after a long time it times out with a script error in the IMC window.
    The log shows this:
    copy tftp flash 192.168.1.10 192.168.1.100_YA_16_11_0019.swi primaryML
    The primary image will be deleted.
    Continue (y/n)? yML
    001M
    002M
    003M
    004M
    005M
    006M
    007M
    008M
    009M
    010M
    011M
    012M
    013M
    014M
    015M
    Validating and Writing System Software to the Filesystem ...
    000M
    switch# ML
    Looking at the logs I see lots (Thousands) of this repeating…
    switch# yML
    Invalid input: y
    Then this:
    switch# yML
    Invalid in
    I just wondered if anyone else had attempted a firmware update with E710P04?
  • 14.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jun 26, 2024 04:28 AM
    Hi SyAc,
    sorry about that, if you could provide the old ticket number we will get this fixed for you.
    Kind Regards
    Paola
    Kind Regards
    Paola
  • 15.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jul 08, 2024 09:31 AM
    Same "yML" problem here. Got it solved?
  • 16.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Jul 10, 2024 04:04 AM
    Depressingly no I have not.
    I have a ticket open but nothing is happening with it...
