Aruba 2540 Captive Portal Redirect not working
This thread has been viewed 54 times
  • 1.  Aruba 2540 Captive Portal Redirect not working
    Posted May 09, 2023 04:01 AM
    Hi everybody,
    I've setup a wired mac-based service with a redirect to a self registration page for guests. I've a guest client connects to the switch, I can see that the correct profile is assigned. But when I try to open a page in the browser I get the following error:
    The connection for this site is not secure. www.google.de uses an unsupported protocol. ERR_SSL_VERSION_OR_CIPHER_MISMATCH; Unsupported protocol; The client and server don't support a common SSL protocol version or cipher suite.
    I've installed a SSL and a CaptivePortal certificate on the switch.
    Any ideas?
    Kind regards
    Matthias
  • 2.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 09, 2023 01:00 PM
    Are you able to browse directly to the CPPM Guest Page URL?
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 09, 2023 05:24 PM
    Yes, if I try to connect to the CaptivePortal everything works fine.
    I had hoped the behavior would be nearly the same as with the wireless Environment.
    If the guest client connects to the guest wifi, a Browser automaticly opens and the client gets redirected to the self registration page.
    Gesendet von Outlook für iOS
  • 4.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 09, 2023 06:27 PM
    Do you mind posting a scrubbed copy of your switch config?
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 10, 2023 05:22 AM
    Switch Config:
    ; JL357A Configuration Editor; Created on release #YC.16.11.0010
    ; Ver #14:67.44.38.04.99.03.b3.b8.ef.74.61.fc.68.f3.8c.fc.e3.ff.37.2f:73
    hostname "HNEVGM040CP"
    module 1 type jl357a
    mirror-port 45
    console idle-timeout 300
    console idle-timeout serial-usb 300
    aruba-central disable
    no rest-interface
    include-credentials
    password operator user-name "operator" XXX
    password manager user-name "manager" XXX
    password minimum-length 8
    radius-server host X.X.X.X key "KEY"
    radius-server host X.X.X.X dyn-authorization
    radius-server host X.X.X.X time-window 0
    timesync ntp
    ntp unicast
    ntp server X.X.X.X iburst
    ntp enable
    no telnet-server
    time daylight-time-rule western-europe
    time timezone 60
    web-management ssl
    ip default-gateway 10.251.2.1
    ip dns server-address priority 1 X.X.X.X
    ip dns server-address priority 2 X.X.X.X
    ip ssh filetransfer
    ip source-interface radius vlan 65
    ip client-tracker trusted
    interface 1
       name "01/01"
       exit
    interface 52
       name "NOT USED"
       exit
    snmp-server community "public" unrestricted
    snmp-server contact "oc.it@opitz-consulting.com" location "Holding OC.IT"
    snmpv3 engineid "00:00:00:0b:00:00:08:f1:ea:50:d1:00"
    aaa accounting update periodic 3
    aaa accounting commands stop-only radius
    aaa accounting exec start-stop radius
    aaa accounting network start-stop radius
    aaa accounting system stop-only radius
    aaa authentication login privilege-mode
    aaa authentication web login radius local
    aaa authentication web enable radius local
    aaa authentication ssh login radius local
    aaa authentication ssh enable radius local
    aaa authentication port-access eap-radius
    aaa authentication captive-portal enable
    aaa port-access authenticator 2-10,12-14,16-30,32,34,36-42,44-48
    aaa port-access authenticator 1 client-limit 3
    aaa port-access authenticator 48 client-limit 3
    aaa port-access authenticator active
    aaa port-access mac-based 2-10,12-14,16-30,32,34,36-42,44-48
    aaa port-access mac-based 1 addr-limit 2
    aaa port-access mac-based 48 addr-limit 2
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 1-48
       untagged 49-52
       no ip address
       exit
    vlan 55
       name "OC-GM-User-Gast"
       untagged 2-10,12-14,16-30,32,34,36-42,44-48
       tagged 49-52
       no ip address
       exit
    vlan 65
       name "OC-GM-ClearPass-Profiling"
       tagged 49-52
       ip address 10.251.2.40 255.255.255.0
       ip helper-address X.X.X.X
       exit
    primary-vlan 250
    spanning-tree
    no tftp client
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    CPPM Profile:
  • 6.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 10, 2023 11:04 AM
    If you run:
    show crypto pki local-certificate
    do you see a cert listed with the usage "CaptivePortal"
    Zak Chalupka
    wifizak@hpe.com
  • 7.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 10, 2023 11:31 AM
    Yes, I´ve installed a cert for Web and one for Captive Portal:
       Name                 Usage         Expiration     Parent / Profile
       IDEVID_CERT          IDEVID        2031/01/26     IDEVID_INTER_1
       IDEVID_INTER_1       IDEVID        2031/01/26     IDEVID_INTER_2
       IDEVID_INTER_2       IDEVID        2031/01/26     IDEVID_ROOT
       SSL                  Web           2025/04/02     SSL
       CPPM                 CaptivePortal 2025/04/02     CPPM
  • 8.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 11, 2023 12:08 PM
    It is hard to say exactly what's going on here without digging into a log session.
    Here are a couple steps I would take for troubleshooting.
     1. Configure an L3/SVI on the Guest VLAN used in the initial Role.
     2. Configure the initial CP Role and associated auth locally on the switch. [see snipet below]
     3. Double check - aaa authentication mac-based chap-radius server-group
    class ipv4 class-dhcp
      10 match udp any any eq 53
    class ipv4 class-dns
      10 match udp any any eq 67
    class ipv4 cppm-captive-portal
      10 match tcp any 172.21.0.200 eq 443
      20 match tcp any 172.21.0.201 eq 443
      30 match tcp any 172.21.0.202 eq 443
    class ipv4 web-traffic
      10 match tcp any any eq 80
      20 match tcp any any eq 443
    policy user guest-captive-portal
      10 class ipv4 cppm-captive-portal
      20 class ipv4 class-dhcp
      30 class ipv4 class-dns
      40 class ipv4 web-traffic action redirect captive-portal
    aaa authentication mac-based chap-radius server-group "lab1-cppm"
    aaa authentication captive-portal profile lab1-captive url https://aaa.lab.arubalabs.com/guest/LabGuest.php
    aaa authorization user-role name guest-captive
     captive-portal-profile lab1-captive
     policy guest-captive-portal
     reauth-period 180
     vlan-id 10
    Zak Chalupka
    wifizak@hpe.com
  • 9.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted May 12, 2023 04:48 AM
    Remove line 20 from:
    Because with this configuration you are redirecting HTTPS traffic, which is not possible.
    Also, it's not possible to redirect www.google.de (or other Google domains, and many other domains) as these use HSTS which force the browser to use HTTP, which can't be redirected and will give you the warnings/errors. Seems like expected with this configuration.
  • 10.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted Jun 06, 2023 04:52 AM
    Edited by MatthiasP Jun 06, 2023 06:11 AM
    Hello Herman,
    am I right, that there is no problem with my configuration, if it's not possible to redirect many domains?
    And what would be a recommendation? How could I get the clients redirected to the self registration page. It is not very user friendly to type in the self registration page URL...
  • 11.  RE: Aruba 2540 Captive Portal Redirect not working
    Posted Jun 30, 2023 10:30 AM
    If you just redirect HTTP traffic (port 80) and drop/deny all port 443, most clients will try to reach a specific website over HTTP to detect if there is a captive portal, and show the well-known popup for guest login. Via that HTTP redirect you can redirect to the login page. Redirection on port 443 has never worked well, and results in certificate errors, and sites with certificate pinning or HSTS don't allow users to be redirected at all. Without explaining all the details, just don't redirect HTTPS traffic as it does not work, but has some bad side-effects like the certificate errors that confuse end-users.
