Wired Intelligent Edge
Aruba 2540 : problem with fiber optic link
  • 1.  Aruba 2540 : problem with fiber optic link
    Posted Jun 10, 2019 04:24 PM
    I meet a problem with a switch Aruba 2540 : It must replace an existing switch (TP-Link) connected with a fiber optic to another building. When I connect the fiber optic to the SFP (J9150D) on the Aruba switch, the link stay down. If I plug on the TP-Link switch, it work. If I plug the fiber optic in a switch Aruba 2530, with the same SFP module, it works !
    What's the problem with Aruba 2540 ? It works with 2530 but not 2540 :-(
    I use the latest version of Aruba OS, and, I tried another Aruba 2540, the problem is the same. The problem is the same with a transceiver 10G. In the other building, the switch is a TP-Link, I have replace it with an Aruba 2540 for test : the problem persist.
    Transceivers TP-Link / Aruba that I used seem to have identical characteristics.
    Have you an idea please ?
    Regards :)
  • 2.  RE: Aruba 2540 : problem with fiber optic link
    Posted Jun 10, 2019 04:39 PM
    It should be supported if I look in the compatibility guide.
    Can you run the command show tech trancievers
  • 3.  RE: Aruba 2540 : problem with fiber optic link
    MVP GURU
    Posted Jun 10, 2019 05:20 PM
    @fl050 wrote: When I connect the fiber optic to the SFP (J9150D) on the Aruba switch, the link stay down. If I plug on the TP-Link switch, it work. If I plug the fiber optic in a switch Aruba 2530, with the same SFP module, it works !
    Hi! there is some confusion going on here.
    The SKU Part J9150D represents a SFP+ Transceiver (so running at 10Gbps).
    Aruba 2540 does indeed support that type of SFP+ Transceivers. It supports SFP Transceivers too...keep in mind that SFP Transceivers run at 1Gbps and, typically, a Short Range SFP Transceiver - also known as SX or SR - supported on both Aruba 2530 and 2540 has SKU equal to J4858C or to J4858D...so, you see, SKUs of SFP versus SFP+ are totally differents.
    Another thing to note is that Aruba 2530 doesn't support any SFP+, only SFP ones...so what are you exactly testing? 10Gbps on both ends? 1Gbps on both ends?
    What are you exactly using on both ends (Aruba side and TP-Link side)?
  • 4.  RE: Aruba 2540 : problem with fiber optic link
    Posted Jun 11, 2019 04:28 AM
    Thank you for your messages.
    In my first post, I reversed the two references (J9050D / J4858D). A summary of my tests :
    FromTransceiver typeToTransceiver typeResult (Link)
    2540J4858DTP-Link SwitchTL-SM311LM-v2.0Down
    2540J9050DTP-Link SwitchTXM431-SRDown
    2540J9050D2540J9050DDown
    TP-Link SwitchTL-SM311LM-v2.0TP-Link SwitchTL-SM311LM-v2.0Up
    2530J4858DTP-Link SwitchTL-SM311LM-v2.0Up
    If I plug the 2540 directly to a switch TP-Link with a short fiber optic cord, it works. By going through the optical fiber between the two buildings, the 2540 does not work. But, it's ok with the 2530 or TP-Link.
    For the result of the command "show tech transceivers" :
    Cmd Info : show tech transceivers
    transceivers
    Transceiver Technical Information:
    Port # | Type | Prod # | Serial # | Part #
    51 | 1000SX | J4858D | ******* | 1990-3657
    52 | 1000SX | J4858D | ******* | 1990-3657
    * third-party transceivershow time
    Fri Jun 7 00:05:00 2019
    === The command has completed successfully. ===
    Regards.
  • 5.  RE: Aruba 2540 : problem with fiber optic link
    Posted Jun 21, 2019 10:00 AM
    Anyone have an idea ?
    Regards.
  • 6.  RE: Aruba 2540 : problem with fiber optic link
    Posted Jun 24, 2019 08:10 AM
    No cabling issue? tx-rx swapped?
    No spanning-tree issue? (bpdu-protection/root-guard) or even loop-protect kicking in?
    what do you see in the log when you connect the sfp?
    show log -r
    Or live logbuffer view:
    debug event
    debug des ses
  • 7.  RE: Aruba 2540 : problem with fiber optic link
    Posted Nov 06, 2019 08:32 AM
    Dear fl050,
    sorry for late reply. If you use a gbps fiber optic modules in SFP+ slots of 2540 switch. You need to set ports speeds that it works with thrid party switches. We exprianced that feature too.
    int x (you SFP+ fiber slot)
    speed-duplex 1000-full (If you have fixed port speed on other side)
    The 2530 Series has some switches with SFP+ ports too which are EOL (J9853A-J9856A). It could could be that there is the same "feature".
    Br,
    Mark.
    EDIT:
    This seems only to help when you have a new module on other 3rd party side when you have 1/10 speed selectable (It appears with intel 1/10G SFPs).
    What show sh int tranceiver [your port] detail?
