Aruba 275 A/C power
  • 1.  Aruba 275 A/C power
    Posted Sep 28, 2017 03:07 PM
    Does anyone know what part number I can use for the A/C power adaptor for the Aruba 275? I found the weatherproof cable part number but not the actual A/C adaptor part number. It is the same as the Aruba 325 - JX990A?
  • 2.  RE: Aruba 275 A/C power
    Posted Sep 28, 2017 06:01 PM
    AP-275 power cable is not the same for indoor APs.
    http://www.arubanetworks.com/assets/og/OG_AP-270Series.pdf
    If you need an AC power cable for US, use
    JW081A PC-OD-AC-P-NA MST2HAC and AP-27x Weatherized AC Power 5m North Amer Cable
  • 3.  RE: Aruba 275 A/C power
    Posted Sep 29, 2017 08:01 AM
    Thanks, I did see the power cable in this document but I'm actually looking for the power brick part number. I read the ordering guide and see plenty of POE adapters but no A/C power brick.
  • 4.  RE: Aruba 275 A/C power
    Posted Sep 29, 2017 08:02 AM
  • 5.  RE: Aruba 275 A/C power
    Posted Sep 29, 2017 09:06 AM
    There's no AC power brick for th 275, just the AC cable straight into the AP.
  • 6.  RE: Aruba 275 A/C power
    Posted Sep 29, 2017 10:39 AM
    Oh, I see! I looked up an image of the power cable and it does makes sense :) Thank you very much...that's great to know.
